faulty multifunction unit, AMR 5919, '97 D-90 - Defender Source
Old October 21st, 2012, 05:38 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
I did some searching (this site and the web) and found the multifunction unit on the '97 D-90 is no longer available. I'm wondering if anyone has had success trouble shooting one or can recommend a good shop that might be able to repair the one I have. This is the plastic box located behind the upper row of dash switches that controls the rear wiper, door chime, dome lights.
Thanks!
Severin
Old October 23rd, 2012, 12:24 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
What is yours doing/not doing?
Old October 23rd, 2012, 02:44 PM
blenkush's Avatar
blenkush
Severin Blenkush
Rear wiper, dome light, key in ignition chime - those I'm certain, might be more but my A/C is down (for other reasons) and I'm not sure if there's a link there. I could bypass on some systems, but would rather attempt to fix the problem before tearing into my harness.
Old October 23rd, 2012, 05:18 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Before you jump to the AMR5919 MF-ECU being bad, know that everything you mentioned is also effected by the "door open" plunger switch. If it's crappy or otherwise the wiring is messed up, that would cause all of the problems you menitoned. I'd recommend checking that first before digging into the ECU or paying big dough for another one, as it's fairly easy to check and trace, and if a replacement is needed, will also be a lot cheaper. (And prevent screaming when a new/rebuilt ECU doesn't fix the problem. )
I was able to find a spare AMR5919 MF-ECU several years ago (mentioned in another older thread), but also was able to fix my stock ECU by opening it and then checking and correcting some cold solder joints and corrosion in the box, in particular on the multipin connection. I've saved the spare for if/when my stock one dies.
Too bad I wasn't able to help you a few months ago. I just moved from the VA Beach area in July/August and could have shown you the possible fixes!
Good luck,
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
90, 97, d-90
'97 NAS Defender 90 ST roll cage and other ST specific components for sale LenB For Sale - Parts 11 August 21st, 2011 09:24 PM
97 NAS 90 "Brake " warning light. Roverlab Defender Technical Discussions 2 May 5th, 2010 06:50 AM
'97 Defender 90 Serpentine belt crown14 For Sale - Parts 0 February 5th, 2010 04:01 PM
97 Yellow 90 gumarcel Wanted 0 November 18th, 2003 11:08 AM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
