Fault Code P0183 - Defender Source
Old February 16th, 2005, 08:32 PM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Fault Code P0183
Check engine light came on, went to Auto Zone and they let me borrow the ODBII reader.
It read exactly as follows:
P0183 Fuel Temperature Sensor A Circuit High Input
Thoughts?
I cleared it, but am wondering about the seriousness of this fault.
Thanks!
Paul
Old February 16th, 2005, 11:15 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Hey Paul, that fault would indicate a defective fuel temp sensor. drive cycle A, i think which means if it's bad, it will probably turn the light on again fairly soon. the sensor adjusts fuel pulse/pressure to the injectors for hot starts. did the light come on or did it flash? was this a hot day or was the engine running warm? post up again if/when it happens.
jeff
Old February 17th, 2005, 05:28 PM
proulx70's Avatar
proulx70
Paul S.
Hi and thanks for the great input! The light stayed on solid and it was not a hot day by any means. I will see if it comes on again.
Is it something that MUST be replaced if bad, or is it just more of a fuel economy issue?
Is it hard to replace? Did you have to do it on yours?
Thanks again
Paul
Old February 17th, 2005, 09:11 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Paul, thanks for the info...here is what the ws manual says about the sensor
"The EFT sensor is located on the fuel rail. This sensor
measures temperature of the rail rather than the fuel.
The resistance varies with changes in temperature.
The signal is used to increase the injection pulse time
when undergoing hot restarts. When the fuel is hot,
vapourisation occurs in the rail which may result in the
formation of bubbles in the injectors. Increasing the
pulse time helps flush the bubbles away and cools the
fuel rail with fuel from the tank.
An EFT sensor fault may not be evident to the driver,
there may be a hot restart problem. The fault is
indicated by illumination of the malfunction indicator
light (MIL)."
If you can, pull the connector off and measure the resistance accross the two pins..engine cold and hot(engine off, of course) that will tell for sure if the sensor is bad. If you cannot measure the resistance at all(meaning that no setting on the meter will give you a number, than the sensor has an open circuit and has failed. No i haven't replaced mine, i've spent too much time diagnosing fault codes. Most sensors can be metered to find out if they are working properly, a very simple procedure.. let me know what you get and we'll go from there...
jeff
Old November 14th, 2008, 07:55 PM
GYM's Avatar
GYM
Gary
97 SW
Resurrecting an old thread...
I think my fuel temperature sensor may be going bad. I get a recurring fuel sensor circuit fault, (but thankfully have never had a hot re-start problem.)
Given that RN wants $152 for a new sensor; I'd like to test mine first to be sure. How do you 'meter' a sensor to find out if it is working properly (as mentioned in the original post above)? Has anyone ever done this?
Thanks.
Old November 14th, 2008, 08:12 PM
proulx70's Avatar
proulx70
Paul S.
Get the new one from British Pacific. They get them wholesale from the OEM manufacturer. Cost me about 30 bucks.
Old November 17th, 2008, 10:08 AM
GYM's Avatar
GYM
Gary
97 SW
OK, great. Thanks for the suggestion.
Have you had that fault code pop up since you replaced it?
Old November 17th, 2008, 11:57 AM
proulx70's Avatar
proulx70
Paul S.
Nope; good to go for over three years now.
Old November 17th, 2008, 04:05 PM
GYM's Avatar
GYM
Gary
97 SW
Excellent. Thanks, Paul.
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
