Fault Code Misfire on #6 cylinder - Defender Source
Old February 16th, 2004, 07:58 PM
dbwitt's Avatar
dbwitt
Darrin Witt
1995 Defender 90
Anybody have any suggestions. My Defender is running great. But, my 99 Series I Disco has a problem. Everytime I let off the gass at high speeds (65-70) the car starts to idle very rough. I put on the break and slow down. It begins to run fine and I am on my way. It is very intermitten. The check engine light came on so I took it to the dealer. They said it was the speed sensor? It was replaced at 400 bucks. I went home and had the same problem. Any suggestions?
Darrin Witt
95 D-90 SW
04 Disco
Old February 16th, 2004, 10:10 PM
www.discoweb.org
Old February 16th, 2004, 10:30 PM
vesparover's Avatar
vesparover
brian bertolini
hey darin I'm in charleston too! Where are you at? I'm in james island- the yellow defender with the treadplate everywhere.
shoot me an email sometime.
brian bertolini
fire, misfire
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
