Fault Code Help (please) - Defender Source
Old September 8th, 2012, 04:42 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Tried asking this on the VDO gauge thread, but figured I'd put it in a new one and see if anyone has a solution to this: Fault code is Vehicle Speed Sensor, and has been popping up since I switched to a VDO speedo on my '97. Somehow, the vehicle speed sensor is no longer sending the speed to the ECU (at least that's my guess anyway). It seems others have gone through this too, but couldn't find a solution from the link below. There is one post of changing the wiring a bit to the VDO, and cutting power to the VSS, but it's not spelled out that well, and am pretty much at a standoff with my code reader. Thanks so much in advance
Aaron
http://www.defendersource.com/forum/...ad.php?t=30383
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
