Fault code help - Defender Source
Old August 2nd, 2008, 02:05 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Fault code help
I need your help guys. My wife's 04 freelander has 4 codes and a problem with stutering.
the codes are:
p0303
p1470
p1472
p1775
The land rover dealership in MD could not find the codes I am in the Hamptons this weekend and the dealership here was a bit more diligent and found them. But had no time to look them up. Can anyone help me with what they are?
Thanks Guys
Old August 2nd, 2008, 03:16 PM
Use this link to read them all
http://www.iequus.com/support/obd2_definitions.php
Old August 5th, 2008, 09:52 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
THANK YOU!
That helps hopefully we can find the culprit ground.
and I am sure I will use the site again in the future.
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
