Fault code 45 and erratic idle - Defender Source
Old June 17th, 2014, 09:19 AM
slatelacy
Slate Lacy
94 ST
94 d90 with 4.6 conversion. Check engine light is on, showing fault code 45. Once the truck is warmed up, the idle is up and down and will occasionally stall out at stop lights. I've cleared the code many times, but it comes back. Any ideas would be awesome! Thanks.
Old June 17th, 2014, 09:46 AM
replace both oxygen sensors and clean the stepper motor. This code is for the passenger side O2 sensor.
Old June 18th, 2014, 04:37 PM
slatelacy
Slate Lacy
94 ST
Replaced both sensors,cleaned throttle body. Still idling weird and the check engine light is back on.
Old June 18th, 2014, 09:20 PM
5 speed or auto?
Old June 18th, 2014, 10:24 PM
Are the throttle springs all on correctly?
Old June 18th, 2014, 10:39 PM
Check the VSS truck might not know it's stopped.
Old June 18th, 2014, 10:57 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
no VSS on the 94 (IIRC).
same issues. after replacing O2 sensors, i relocated the ignition amp off the diz, put on real genuine cap, rotor, and wires, checked the base idle, then swapping in the genuine IAC motor.
that seemed to do the trick.
also check the t on the hoses up front and the hose at the back of the plenum for cracks. could cause a vacuum leak.
just saying.
now i have coil packs...but i got to know that issue well owning a 94 classic for a decade.
Old June 18th, 2014, 11:57 PM
slatelacy
Slate Lacy
94 ST
5 speed. Truck seems to be running better, but threw fault code 44 this time and still just about dies out at warmed up idle. Very weird.
Old June 19th, 2014, 05:31 AM
Also check for vacuum leaks around the intake.
Old June 19th, 2014, 08:52 PM
slatelacy
Slate Lacy
94 ST
Update: No vacuum leaks or bad o2 sensors. Truck completely cut off coming down a hill today and I had to pull over and restart. Still throwing 44-45 codes.
Old June 19th, 2014, 10:16 PM
You don't remember correctly there is a VSS on a 94.
When the truck is slowing down the output of the VSS signals the ECU to get ready to start doing idle control. When the vehicle is stopped the ECU does full idle control.
Doesn't anyone ever read the documentation for the 14CUX??
Old June 19th, 2014, 10:33 PM
No.
VSS will definitely cause the stalling issue when coming to a stop or when coasting.
Old July 5th, 2014, 10:12 AM
UTRPh's Avatar
UTRPh
Danny V
94 D90 #1260
So how do you test the VSS
Fixin to start tracking down my stop/stutter problem. I'll hunt down the vss like y'all said on my other post but how do you test it?
Anything worth doing is worth getting carried away with(ancient druid saying)
Old July 5th, 2014, 02:27 PM
Read the 14cux test documentation. Google is your friend.
Erratic Electrical Headaches with Headlights, Blinkers and High Beams spammer Defender Technical Discussions 5 January 19th, 2014 09:16 AM
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
» Defender Registry
Hilda
badvibes
Pancho
LPP
Add your Defender
