Fault Code 45? - Defender Source
Old October 19th, 2004, 09:44 AM
Troys
Troy Smith
1995 D90 SW
Fault Code 45?
My 95 D90 sw is giving me a Fault Code 45. My manuals tell me 45 and 46 are the O2 sensors. Is 45 the drivers side or passenger side? One manual tells me it is the right side but is that looking at the truck or sitting in the truck? Maybe my brain is just not working today!
Thanks!
Troy
Old October 19th, 2004, 10:47 AM
If you have not then I would say reset and wait for it to happen again, if it does then I would try unplugging the passenger side O2 sensor, if you get another fault then I would say it is the driver side that is bad, but this is just a guess.
Old October 20th, 2004, 01:04 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Troy,
Yes, codes 44 and 45 are O2 sensor codes. I think code 45 is drivers side, but I wouldn't swear to it. Keep in mind that 14CUX is a very basic fuel management system that needs some interpretation. A code 45 means that the ECU could not adjust the fueling to it's liking on that bank. It does not necessarily mean a bad O2 sensor, there could be an ignition misfire, air leak, exhaust leak, etc. that can trip the fault. I would look closely at the ignition system for any sign of misfiring as well as tightening the connector pins in the O2 sensor plugs...they are known to get loose and cause intermittent connections.
Cheers, Rob
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
