Fault Code 15 - Defender Source
Old March 9th, 2004, 05:39 PM
Troys
Troy Smith
1995 D90 SW
Question Fault Code 15
I had my 95 D90 SW diagnosed today and it came up Fault Code 15 - Fuel Thermistor. Can this cause the catalytic convertor to blow out? My check engine light came on, fuel mileage went to heck, then cat pieces started coming out the tailpipe. I thought for sure it would end up being a bad HO2 Sensor.
Troy
Old March 9th, 2004, 06:21 PM
HMMMMM........
The Fuel Thermistor tells the ECU what the temp of the Fuel is, I can't see this causing the Cats to blow up.
Cats die all on there own when they get clogged up, then your gas mileage goes to down and then the insides break up and come out the back just like you said.
I would try resetting the ECU after you check all the codes and watch too see if more codes come back. If they do come back check here
http://www.rangie.com/articles_topic...at=6&subCat=26
to get a better idea about what they mean. I have often had codes come up that did not return after I reset the ECU.
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
