Fault Code "03" - Defender Source
Old December 17th, 2004, 11:26 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Fault Code "03"
The 110 just threw a fault code "03", which is not in the 'book'. Anyone know what it means? Also accompanied by a drop in idle speed. I'm running a 14cux ecu, came out of a 95 disco but I think all 14cux's are the same.
Doug W.
Old December 17th, 2004, 11:42 PM
I don't know how good this is but I found it in the FAQ
OBD error code #3 means "memory interruption" in the computer. It can be caused by water (if anyone remembers the VT trip) or an electrical surge from the "thingie" that sends electrical current to the distributor
I say reset the ECU and see if it returns.
Old December 18th, 2004, 03:13 PM
Doug's Avatar
Doug
Doug Walker
Thanks, Mike. Adding the word 'memory' to a google search and I found a reference that said 'memory cleared'. I drove her this morning and the fault turned itself off -- then the CPA took about 30 minutes to 'reeducate' itself to the proper idle setting. All good.
Doug W.
sorry 'ECU'. Must have end-of-year on my brain.
Old March 26th, 2005, 12:20 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Hey guys,
I just found out that this is what is happening to my truck. It happens a lot and I am wondering if there is anything I can do about it. I get the #3 fault code, and when I press in the clutch the tach goes crazy and sometimes shuts the car off.
How do I reset the ECU? and is this just a fluke that happens a lot to me?
Kris
Old March 26th, 2005, 08:06 PM
Doug's Avatar
Doug
Doug Walker
http://www.pangeaexpeditions.com/tech/obdcodes.html
Instructions on Fault Code #2 on how to reset. I haven't a clue why the #03 code occurs. Lucky for me it stopped recurring.
Good luck with it, Kris.
DW
Old March 26th, 2005, 11:21 PM
Billakris's Avatar
Billakris
Kris
Thanks Doug,
Hopefully I can figure out how to fix it so it quits making my truck run like sh*t
Kris
Old March 28th, 2005, 06:07 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
When my ECU coded with a #3 I opened up the ECU to find that there was water pooling in the case. dried it out and reinstalled. also cleaned the contacts and used lots of dialectic grease. no prob yet... knock, knock. That was in '03.
Insert pithy quote here.
Old March 28th, 2005, 09:31 PM
Billakris's Avatar
Billakris
Kris
Are there any problems with opening up the ECU? I thought i heard somewhere that you shouldnt dissconnect it.
Kris
Old March 28th, 2005, 09:36 PM
Doug's Avatar
Doug
Doug Walker
You can switch them out like spark plugs. Pull one, put another in, etc. Just don't give the circuit board a static discharge by accident if you decide to take the actual box apart - rarely but possible could cause issues with the firmware loaded in the chips.
Doug W.
Old March 29th, 2005, 01:11 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
just treat it like you were upgrading RAM on your PC and you'll be fine.
Old March 29th, 2005, 03:56 PM
Billakris's Avatar
Billakris
Kris
sounds good,
thanks guys
Kris
Old June 27th, 2005, 03:14 PM
Billakris's Avatar
Billakris
Kris
I keep getting this 03 code and its starting to piss me off. It happens all the time. This morning I didn't even get out of the driveway before it died on me. It only happens when the car is in neutral or i have the clutch engaged, but the check engine light pops on before that and the car looses power and lurches very suddenly. After that when i get to a stop sign its dead. I really dont understand what this is. It seems to be random. Any ideas? Thanks
Forgot to mention, I opened up the ECU cleaned it with some electronic spray then put it in a bag in a tupperware box and sealed it up. So im pretty sure its not moisture in the ECU.
Kris
Old June 27th, 2005, 03:42 PM
Originally Posted by Rick in the FAQ
OBD error code #3 means "memory interruption" in the computer. It can be caused by water (if anyone remembers the VT trip) or an electrical surge from the "thingie" that sends electrical current to the distributor.
-Rick
I would check the wire running from the coil to the ECU and the wire running from +12 volts to the coil. The first is white with black strips, the second I think is just white. They both come off the coil going back toward the firewall. THe other wires on the coild should go to the distributer, I might have a look at them also just too make sure all the connectors are good.
Is there anyone near you that you can try another ECU or let him try yours to try and narrow down the problem?
Old June 29th, 2005, 02:51 PM
Billakris's Avatar
Billakris
Kris
Mike,
I checked all the connections and it died the next time i took it out. Any other suggestions to rule things out? I have a friend that I could swap ECU's with, but hes out of town for the summer. Hes my only 90 connection around here.
Thanks for the help,
Kris
Kris
Old June 29th, 2005, 03:49 PM
You might try http://www.carcannibal.com/rover/ to get a new ECU to try, you just need a 14CUX, it can be from anything that has a 3.9 just as long as it says 14CUX.
Old July 18th, 2005, 10:38 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
I started getting this code recently. Is there a better explanation for this code than what I am reading here? Anyone have more experience with this? Is it a sign of an ecu needing replacement?
"Uhh...I think they all leak like that."
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
Fault Code 15 Troys Defender Technical Discussions 1 March 9th, 2004 06:21 PM
