Fastening the Seatbelt to the C Hoop - Defender Source
Old October 25th, 2011, 10:55 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
So, I finally installed the rear cage on my '95 90, but don't have the bolts to mount the seat belts to the c hoop. What hardware is used for that? Thanks.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old October 26th, 2011, 06:06 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Grade 8 10mm dia x 70mm bolts and collars available by jefhuf. Info here : http://www.defendersource.com/forum/...ad.php?t=33787
Old October 26th, 2011, 06:19 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Thanks Russell.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old December 3rd, 2011, 10:23 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
So, I'm having difficulty locating Grade 8 10x70 bolts. Seems they come in U.S. sizes, but can't locate them in metric. Anyone have any ideas?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old December 3rd, 2011, 11:55 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
USE:
http://www.mcmaster.com/
It will ship in less then two days. Goodluck.
Old December 4th, 2011, 08:52 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
you can also check out boltdepot.com if you don't want to buy a pack of bolts
Old December 4th, 2011, 09:45 AM
Rosproline157
Matt Oaks
1992 Defender 90
Most of the bolt as McMaster are sold individually
Old December 4th, 2011, 01:45 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
really? I have found the exact opposite...most of the common sizes at McMaster will be packs of at least 5, if not 10 or 25. that being said, I use McMaster often as I typically do not buy just one bolt!
Old December 4th, 2011, 03:01 PM
Rosproline157
Matt Oaks
1992 Defender 90
We use them all the time for work, its a little costly verses your traditional fastener companies, but a great resource for odd size bolts. Not to mention metric fine thread structural bolts. Their nuts and washers typically coming in larger qtys but not the bolts.
GoodLuck!
Old December 6th, 2011, 11:15 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Are they 1.25 or 1.50 threads?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old December 7th, 2011, 09:45 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
should be 150
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 7th, 2011, 12:45 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You will find grade 8.8 used for metric. You are right that grade 8 is US sizes
Old December 7th, 2011, 01:13 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Thanks all for the help. I tracked them down at Monster Fastener through Amazon. The shipping was relatively reasonable and they had the proper size. Not all retailers had the correct size available, nor in a flange style, which is what I was looking for.
By the way, the grade 8 equivalent in metric is 10.9.
1997 P38 4.6
1998 P38 4.0
2011 LR4
hoop, seatbelt
Rear seatbelt Q's Seanh Defender Technical Discussions 5 December 1st, 2005 08:40 AM
Middle hoop of roll cage for ST evilfij Wanted 0 June 18th, 2005 12:47 AM
Seatbelt bracket Chaucer Wanted 0 April 16th, 2005 08:53 PM
Plastic Hard Top Fastening scot Defender Technical Discussions 1 October 24th, 2004 08:49 PM
97 SW Rear Hoop Pix Yousef dnewman9 Defender Technical Discussions 4 July 20th, 2004 01:55 PM
