Fastener - Front Signal Lamp Bezel - Defender Source
Old January 16th, 2012, 08:24 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
In the process of removing the bezel of of my front turn signals, I encountered a frozen bolt. The problem is that in trying to remove it the fastener assembly just spun, so I couldn't get any force on the bolt. There's a similar type of fastener for the license plate as well.
What are these fasteners called and can they be easily removed and replaced?
Thanks.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 16th, 2012, 09:46 PM
In my experience it is usually the small fasteners that ruin your day.
Old January 16th, 2012, 09:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It's called a rivet nut. They are easy to replace but you need a rivet nut tool to do it. Mcmaster Carr or Harbor Freight has them. Obviously get the metric size to match the rest.
Old January 17th, 2012, 12:13 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Thanks Manimal, I'll check it out.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 17th, 2012, 06:20 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Very true, and there's always one that turns a simple job into a project. On this delal I decided to freshen up the headlamp and the lenses. So, 15 screws come out without an issue, but there's that one laughing in my face.
------ Follow up post added January 17th, 2012 06:29 AM ------
Can they be replaced from the front or is it necessary to get behind the nut? Also, can they be removed with a screw stuck in them?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 17th, 2012, 01:12 PM
Usually they are used because you have no access to the location from behind. Worst case you can cut/grind the screw off and drill them out and push the remaining part through and replace them, but it can be a pita.
Originally Posted by pendy
I'm here for the D's
Old January 17th, 2012, 01:35 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
I've been reading up on rivet nuts today and yup, the drill out is the way to go. Have to be careful to avoid cutting into the sheetmetal.
The install seems pretty straightforward. Any pitfalls to avoid?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 17th, 2012, 01:39 PM
put some tape on the surrounding sheetmetal and don't slip Start with a small bit to get a nice centered pilot hole started and take your time.
lamp, signal
Wanted 1994 D90 Left Front Turn Signal Lamp Assembly kylexh Wanted 4 February 15th, 2010 01:56 PM
94 front bumper with lamp guard bjenk For Sale - Parts 1 December 14th, 2007 01:38 AM
FS: D-90 Parts (Bikini Top, front bumper, wagon seat back cover, shift lever bezel dzientek For Sale - Parts 5 March 16th, 2005 12:09 PM
Range Rover Classic Front Lamp Guards NashvilleRedD90 For Sale - Parts 0 January 16th, 2005 03:16 PM
