Fastback Top with Full Rollcage? - Defender Source
Old October 9th, 2005, 02:02 AM
D90JMUR
Jim Murray
1997 Defender 90
Question Fastback Top with Full Rollcage?
FASTBACK Top with Full Rollcage???
Is it possible to install and use a "Fastback" Bestop Top with the Full Soft Top Rollcage?
Has anyone adapted a Fastback top to fit? Cutting holes for the cage bars, etc?
The "Fastback" top that I am describing can be seen on pics at posting entitled "FAST BACK Bows and fabrication" on 3/23/05 by PaulB
Any suggestions (especially pics) or experiences would be greatly appreciated!
Thanks in advance,
Jim
Old October 9th, 2005, 11:42 PM
D90JMUR
Jim Murray
1997 Defender 90
Basically, I am looking for a cheap and simple way to create a half-cab top with a tonnue cover to cover the back area. I want something I can take on and off quick and easy, that covers the entire cab from rain if necessary.
Any help or suggestions would be awesome!
Old October 10th, 2005, 06:56 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i removed the rear roll cage and had a badger top ect fitted.they fitted corner pieces so i can still fit the roll cage .
see this thread for picture
Half Cab
3rd low and BOOT IT
Old October 12th, 2005, 08:53 PM
D90JMUR
Jim Murray
1997 Defender 90
Any other advice?
Anyone have other suggestions for a half cab? What about a bikini and a drop curtain?
Old October 12th, 2005, 09:50 PM
Krna
Andy Krna
1997 D-90 ST AA Yellow
Bikini and Drop curtain is what I have but be prepared to still get wet in the rain and cold if you live anywhere it is cold. There is a gap that is open between the rollcage and the window, as well as a small slit where the drop curtain meets the bikini snaps above your head.
Old October 13th, 2005, 04:51 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Hi Jim,
I don't think it's possible to use the fastback top with the full roll cage. You will definitely have to do some pretty serious cutting and modification. The fastback top has a bow attachment that fastens to the safari cage after removing the two side bars. This piece is pretty important as it keeps the roof from sagging in the rear, making it virtually impossible to see out of the back window without it. If you are interested in the fastback top...just bite the bullet and remove the rear safari cage (rear hope, bow, and side pieces). I have a fastback setup and I love it. I never use the rear tub for anything other than hauling my gear around. However, if you want to have passengers back there...it's impossible with the fastback setup...unless you remove the top. It is also ridiculously easier to remove the whole top. I can put my fastback top on in about 3 minutes...the full softop setup takes much longer. The fastback is also a little more friendly in the winter because the cabin heats up much quicker.
Just my $0.02...
ac, cage
Perfect Fastback Top for Trade or Sale boshea For Sale - Parts 5 September 11th, 2006 09:03 AM
FS/Trade: fastback top Jim For Sale - Parts 3 April 4th, 2006 08:21 PM
110 top, 3-door solid sides, full rear door Method PHX For Sale - Parts 7 March 10th, 2006 04:07 PM
Full Aluminum Hard top and Rear Door Buckon37s For Sale - Parts 12 April 7th, 2005 10:02 PM
SW top on a ST with ST rollcage? Chris Cox Defender Technical Discussions 13 July 27th, 2004 09:50 PM
