Fast back top water control - ideas? - Defender Source
Old April 13th, 2007, 09:57 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
The fast back top has a steep angle over the rear tub area. On the left and right of the rear window, the zippers end at the bottom leaving a 1/4 inch gap. Gosh, would you believe that water, following the laws of gravity, runs down the angle, through the 1/4 inch gap and goes into the truck. Go figure! This would be OK if the tub itself was water proof - indoor pool/hot tub - but alas it too leaks. Bummer.
Anyone out there come up with a snazzy solution on managing the wate flow? I'm thinking of making 2 beer bongs, using them a few times to steady my nerves, then installing them inside the top under the gaps with the hose leading towards/out the tail gate.
Ideas I have already thrown out
1. Sell the top and replace - sorry guys
2. cover/close the gap -
a) failed repeatedly at this
b) fast back window bottom is lower that the tub sides so water would pools there anyway
3. Sell the D90 (HA!)
4. The Zen approach - bugger it (did not work)
Old April 13th, 2007, 10:07 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I would have to actually see the top in use (I've never seen a fastback installed in person) but I would imagine if you took it to a custom canopy/top/sail maker that they could come up with something easy and relatively inexpensive to modify this. I would find a local place that does this kind of work and let them take a look at it and see what they say...after all, they do this for a living.
Old April 13th, 2007, 11:07 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
fixed!
Hey Paul, I removed the back window. It reduced the amount of leakage by nearly 50% (HAHAHA).
Duct tape worked for a while...... I love my fastback and would love to find a cure.
You and I need to find some photos of badgerman in a compromising situation and blackmail him into making us a couple fastback tops!
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old April 13th, 2007, 11:55 AM
tim
Timothy Homewood
Defender 50th going topless
I also wish the Badgerman would take up this challenge..cheers, tim
Old April 16th, 2007, 10:03 AM
paulb's Avatar
paulb
Paul / Boultbee
Andrew,
Look at my avatar as the fast back is on there. Here are three others.
Look at the back shot.
ID:	9022   Click image for larger version
Name:	fast back compr pix back shot.JPG
ac, water
Well Equipped Red Soft Top '97 D90 for Sale - Priced to move fast! muskatd For Sale - Vehicles 11 May 31st, 2014 09:07 PM
Painted Hard Top JimC Misc. Chit-Chat 11 November 23rd, 2005 01:18 PM
FAST BACK Bows and fabrication paulb Defender Technical Discussions 0 March 23rd, 2005 04:02 PM
Differences between metal and fiberglass top jaherring Defender Technical Discussions 5 June 19th, 2004 05:59 PM
