Fan switch? - Defender Source
Old March 28th, 2008, 11:01 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Fan switch?
So I have been having overheating issues (sorry to bring up a dead horse topic). I decided to replace the fan switch before I go the clutch route. I locate the fan switch to remove it and there is nothing plugged into it, just the 2 prongs sticking out??? Guess I found my problem... What should be connected and where would I find it?
Thanks guys!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old March 28th, 2008, 11:19 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
http://www.flex-a-lite.com/auto/210-54997-RAD.pdf
3rd low and BOOT IT
Old March 28th, 2008, 11:46 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Thanks Jimmy, but this is not an electric fan, it is the stock unit. The "switch" I am referring to is the brass plug with the 2 prongs that threads into the rad hose. Should there be anything attached to it?
http://img152.imageshack.us/my.php?image=001vr8.jpg
Old March 28th, 2008, 12:02 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Are you talking about a swich for the A/C fan or an aftermarket radiator fan?
The A/C fan doesnt really affect engine cooling. Several people though have wired the fan to run on a manual overide switch to help overheating without having to run the A/C compressor.
Before investing in a new fan cluch I would look at the electric radiator fan like the flexlite solution in the previous post. It has worked very well for me. There is good info on this board if you search 'flexalite'. Plus they have a new twin high output 'puller' model this year - #280 or 290 I think.
Owen
The 'switch in the photo is to be connected to the A/C circuit. Again it wont have any effect on your overheating.
"I think you need a little weatherstripping - right here..."
Old March 28th, 2008, 12:34 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Ah, thanks Owen. No A/C for me, so that it the reason for the bare switch.
Old March 28th, 2008, 01:03 PM
owen's Avatar
owen
Owen Jones
Our Buick aluminum V8 is prone to overheat especially at lower speeds and low revs when there is little airflow. Before spending money read the theads on this board and do inexpensive things first like backwashing the radiator gills, coolant flush, thermostat change etc.
I mainly use the D offroad with low speeds and revs. In the end I opted to go the Flexalite route and havnt looked back since.
Best!
Owen
fan, switch
110 Fan Switch bjf Defender Technical Discussions 4 May 13th, 2009 11:59 PM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
