Fan speed control switch isn't working - Defender Source
Old June 16th, 2016, 04:14 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Ever since I got my 95 D90, the fan speed control has been finicky. Over time, it has downright failed. Basically, its either off, or kind of on. When it does turn on, its on full blast. And the only way that I was able to turn it on was to smash the lever all the way down.
Letting go of the lever resulted in the fan shutting off. Putting downward pressure on it turned it back on. If i was lucky, i was able to remove my hand and the heater would stay on for a while. I tried taking it apart, cleaning the contacts with contact cleaner and no luck.
Now, it doesn't even work at all. What's worse is that the lever itself gets extremely hot to the touch and in the down most on position I can even start to smell something burning due to the heat. Needless to say, I don't do that anymore.
Has anyone else had this symptom? Is the only solution to replace the entire lever mechanism? Is there a place to get one of those without taking a second loan out on a house?
Old June 16th, 2016, 08:25 AM
There's actually a "board" (sort of like a circuit board, that the lever makes contact with) behind that lever. I had mine break/crack at one point, so it wasn't making contact in all places and would act as you describe (without the burning smell though).
I'd start there as it's a pretty simple circuit, and unscrew the fan speed lever right off the binnacle and have a look at it to inspect the board for cracks, low points, or spots where it is not making contact (don't disconnect the cable though, just unscrew to take out and inspect).
I ended up having an old/spare lever, so I actually just swapped the board (drilled the old rivets out from both units, riveted it into place on my existing fan speed control unit and all was good to go).
PS - keep in mind that even when functioning, the "2nd position" is very feeble at best...you may want to verify that the 2nd position actually isn't working or turning on the blower - sometimes it can be on, but deceiving since the blower barely spins up to move air.
Also it's probably worth testing the blower unit in the engine compartment as well....run 12V (and ground) directly to it via the pigtail using a couple of wires or bullet connectors (one male, one female). Make sure it spins up when running direct power without any issues/etc. This will just be a 1-speed test (full blast) but at least you can verify it's not an issue on the blower end with excessive resistance or similar.
Old June 20th, 2016, 02:05 AM
Zooraya's Avatar
Zooraya
Bani
1995 NAS D90
Thanks for the tips, Jason. I've unscrewed it from the binacle a couple of times without removing the wires. But you really don't have a lot of room to work with unless you do disconnect the cable. Is it really difficult to get it connected again?
I'll give it a go based on your advice once I get it back from the shop (currently getting my transmission swapped). Also, looks like some people have retrofitted blower fans of other makes into the factory housing to improve the overall air movement. I'd love to have more than a binary setting for the fan, and if that means getting a two or three speed system from another vehicle and carving it up to make it fit, then I may just end up doing that.
Old June 20th, 2016, 07:57 PM
It *shouldn't* be that difficult to connect it again, it's got some squirrely looking circlip/s-clip thingy that holds in place.
For the retrofit of upgraded blower motors/fans, I'd say start reading this thread at post #29 and gives you some good pics/etc (in this example it is the VDO/GM PM137 motor that was used, though the same factory switch with the same speed settings & resistor stays in place...but it does help with greater air movement on the "full" setting):
http://www.defendersource.com/forum/...tml#post396404
fan, switch
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Tapatalk app isn't working any more for this forum EnduroPro Support & Suggestions 13 January 18th, 2014 02:14 PM
New, never installed cruise control kit! Yes, cruise control for your D! - For Sale HeloBubba For Sale - Parts 6 August 4th, 2013 10:52 PM
Defender fan speed switch used draaronr For Sale - Parts 0 January 1st, 2005 11:22 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
