Fan replacement - Defender Source
Old December 26th, 2004, 11:46 AM
davedeojay
David Deojay
Fan replacement
Hi, I was running a set of Ken Low Electric fans in my 94 Defender. I was at my local shop for a head gasket job and they pointed out that sometime in the future my radiator would need replacement or repair. Now seemed as good of time as any so I took my radiator to a local shop expecting a repair and to add one more core. When I picked it up they (I guess being generous) had added at least two cores filling up my radiator completely now my Ken Lows don't fit between the engine and the radiator. Can anyone suggect a thiner "pulling fan" or perhaps a "pushing fan" I could mount in the front ?? Would a Land Rover a/c fan do the job ?? Dave
Old December 26th, 2004, 12:02 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Might want to check out the flexi-a-lite 210. Or the flexi-a-lite family if fans. http://store.summitracing.com/esecti...500+4294924499 I have the Be Cool BCI-75007
Jimmy Buffett
Old March 22nd, 2005, 01:07 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
About the flex-a-lite fans, or any electric fans for that matter, do you have to do anything special when crossing deep water? Do you somehow seal up the wires or are they already made to handle that kind of water?
Thanks!
Old March 22nd, 2005, 01:27 PM
I turn mine off for deep water, not only does it save the fans but it keeps water from being sprayed on the Distributer.
Old March 22nd, 2005, 03:31 PM
cbass's Avatar
cbass
Bradlee Duncan
But as for all the wires, is there anything to worry about? Basically I am just wondering if the fans are waterproof right out of the box.
Old March 22nd, 2005, 03:49 PM
They are pretty good and if you tape up all your connections you should be good, the stock wiring harness is more prone to water then the fans.
Old March 22nd, 2005, 08:52 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I'm just about to add a core to my radiator & had the same concern (I have aftermarket electric fans). I will have to make sure the guys add only ONE core!
How many cores are in the stock radiator - two or three? Without the cap it's hard to just look in and count..
Old March 23rd, 2005, 07:57 AM
I am pretty sure the stock has 3 cores. I would think that the Flexalights would fit with a 4 core radiator. If not you could get pushers instead of pullers but I think they would be harder to mount.
Old March 23rd, 2005, 01:32 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Maybe I just dont understand the logistics of all this but here are a few thoughts.
My 95 has A/C, so it has a pusher fan, which seems to fit in there fine in the front.
As far as electric fans, isnt it a smarter proposition to have them as pushers...than pullers, since the heat is an enemy of these things?
...just a thought.
-arbi
Old March 23rd, 2005, 01:45 PM
Pullers seem to work better then pushers. The little pusher AC fan is small next to the Flexalite and less powerful. If you have AC it wold be very hard to mount the fan in front as a pusher. The AC pusher fan helps but you will have much better cooling without the AC system in there.
Old March 23rd, 2005, 02:00 PM
arbik
Arbi Karapetian
Good to know.
Thanks for the info Mike.
Like I said..I dont have any practical experiance with this truck..but in Jeepin'..folks usually opted for pushers..due to the heat issue.
Another thing to consider (and I dont mean to hi-jack this thread)
I read about these metal fan blades..that you can replace your stock plastic ones with, so they dont self distruct.
Just in case you decide to go back to stock configuration.
-arbi
ac, fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Imperial Fan Clutch replacement souza Defender Technical Discussions 11 August 19th, 2008 11:36 PM
Fan Clutch Replacement JMPDIV82 Defender Technical Discussions 8 December 27th, 2007 10:00 AM
Fan Belts Replacement kleedee Defender Technical Discussions 6 August 15th, 2005 09:15 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
