Fan Near Radiator Came On - Defender Source
Old May 25th, 2012, 01:38 AM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
I heard for the first time today what sounded like an engine fan turn on after I parked my car and removed the key. It seemed like a cooling fan near the radiator. It shut off by itself so I don't think I should be worried about it. It was also pretty hot today in Texas and I did a bunch of driving.
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old May 25th, 2012, 01:56 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Its the AC condensor fan in front of your radiator. Its controlled by the ECU and can be turned on if the ECU senses the truck is hot even if the AC is not running or the truck has just been switched off but the main relay hasn't yet dropped out.
Old May 26th, 2012, 01:57 AM
hunterjah's Avatar
hunterjah
Jesse Hardin
Thanks Ian, is it common for the fan to come on. Nothing I should be worried about right?
Current Stable:
Previous Rovers:
Old May 26th, 2012, 02:47 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Nothing to worry about unless its starts happenng all the time.
Old May 30th, 2012, 10:54 PM
seattlejanzen's Avatar
seattlejanzen
Ryan Janzen
1997/Defender SW
this just started happening to me last week as well...and it's been happening every day since. I've owned my 1997 Station Wagon for 12 years and this is the first time i've ever heard this fan.
Any ideas as to what i need to fix/replace?
thx!
Old May 31st, 2012, 12:14 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
You're running hotter than normal and your ECU is using its back up system to compensate. Check your cooling system as it sounds as though its struggling to cope.
Old May 31st, 2012, 02:46 PM
seattlejanzen
Ryan Janzen
1997/Defender SW
ok, thanks! what's weird is my temp guage looks fine.
Old May 31st, 2012, 03:35 PM
It is basically an idiot light on a stick.
Do the cooling system checks (rad wear, does it hold pressure, leaks especially water pump weap hole etc.)
fan, radiator
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Did 1995 SW D90s come with an electric fan? arbik Defender Technical Discussions 8 March 1st, 2005 01:27 AM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
