Fan is wobbling - Page 2 - Defender Source
Old August 23rd, 2010, 03:16 PM
Because you have to take more stuff off to get to it.
I did it on chicky when I got her. I probably posted how long it too me to do it back then. IIRC ~3 hours is about right compared to ~1 hour for a serp belt truck.
Old February 18th, 2014, 08:21 PM
GYM's Avatar
GYM
Gary
97 SW
Re-resurrecting this old thread again. 97 4.0 serp belt is tight. Fan is tightly bolted to viscous. Engine off. Fan assembly feels loose, can move it front to back 1/16 inch or so. It looks like there is play in the viscous where it bolts to the waterpump.
Am thinking it is a bad viscous rather then water pump. Is that possible, or is it just a head-fake and its really a water pump going bad?
None of the viscous threads I read talked about looseness of fan.
Old February 18th, 2014, 08:25 PM
Mine is a '94 3.9, but my fan was loose as described above and it was the fan clutch (not the water pump). Replaced it and all was back in order.
Old February 18th, 2014, 09:05 PM
I suppose that is possible. The bolts could back off, the fan clutch could be shot somehow. Easy enough to remove the fan clutch to check, but I would be on water pump.
Old February 18th, 2014, 11:06 PM
Mine was wobbling 1/4",
The pump was shot, so I did that and the fan clutch at the same time.
95' D90 - daily driver..
fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
RUDD 4x4 GRIP Chains & Kenlowe Fan kit for Sale Barnett Childress For Sale - Parts 0 May 18th, 2005 07:24 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
overheating issue--viscous fan Davis Defender Technical Discussions 5 August 4th, 2004 12:11 PM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
