Fan cowl - Defender Source
Old July 27th, 2016, 11:07 AM
Ai91
Anthony
97 defender 90
Fan cowl
Hi guys. I can't seem to find an upper fan cowl for a 97 4.0 v8 d90. I ordered one that I thought was for the truck but when it came it was for a disco. Does anyone know where I can find one? Is there a way to make the disco one fit?
Old July 27th, 2016, 11:13 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
If you're talking about the upper removable fan shroud peace with the clasps on it, then it's the same as a disco with the GEMS engine. Pics would help
Old July 27th, 2016, 11:26 AM
Ai91
Anthony
97 defender 90
yes..
ID:	154622   Click image for larger version
Old July 27th, 2016, 12:26 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yep those are NLA. For the GEMS motor with serpentine belt the Disco shroud needs to be used. It needs to be modified just a little however.
Land Rover 110
Old July 27th, 2016, 12:56 PM
Ai91
Anthony
97 defender 90
thanks. I'm headed to the shop now. Any advice on how it should be modified?
Old July 27th, 2016, 01:21 PM
Chris B
72 + D1 drivetrain =?
Dang...been so long since I did mine I dont recall....
Old July 27th, 2016, 01:50 PM
Capt Milks's Avatar
Capt Milks
If I recall correctly the top piece fit with out modification but the main piece had to have mounting brackets made at the top, holes enlarged for the 2 hoses and slits made for the bottom brackets to take hold.
Land Rover 110
Old July 27th, 2016, 01:53 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
I did one for my self about six years ago, and I remember having to cut out a small notch in the Disco part number shown. It has been a long time, though.
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'04 G4 Disco II
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old July 27th, 2016, 02:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
So it looks like ESR2847 and ESR3226 for the lower cowl and the removable upper piece.
If it has to be cut anyway, does it matter if use an old RRC one piece cowl?
Because I have several of those lying around...
Or...how does one mod a pre-Gems D90 cowl to fit the GEMS 90?
I dont have the rad or the hoses in so I cant picture where it lines up with the fan...
Rent my
Old July 27th, 2016, 03:04 PM
Chris B
Jeff: When LR went serpentine the alternator moved over towards the left fender. Pre serp shrouds won't work.
Old July 27th, 2016, 03:15 PM
Ai91
Anthony
97 defender 90
So it looks like ESR2847 and ESR3226 for the lower cowl and the removable upper piece. If it has to be cut anyway, does it matter if use an old RRC one piece cowl? Because I have several of those lying around... Or...how does one mod a pre-Gems D90 cowl to fit the GEMS 90? I dont have the rad or the hoses in so I cant picture where it lines up with the fan... .
just tried using a one piece off a RRC and couldn't work. Had to order the disco part
Old July 28th, 2016, 07:17 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
ha ha Well, there goes that idea- Thanks Anthony!
Rent my
WTB LHD Instrument cluster, cowl, and cowl stiffener flananuts Wanted 0 September 23rd, 2014 03:31 PM
300Tdi / Fan cowl / high heat triple9music Defender Technical Discussions 13 June 6th, 2012 02:16 AM
300 Tdi Fan Cowl Fivespddisco For Sale - Parts 3 May 25th, 2011 11:37 AM
Upper Fan Shroud/Cowl - Part #ESR3226 specops1526 Wanted 1 April 23rd, 2010 08:25 AM
Viscus Unit, Fan Cowl, Alum Rim, Quarter Panel hank17 For Sale - Parts 1 October 26th, 2007 01:43 PM
