Fan Clutch Wrench - Defender Source
Old April 6th, 2011, 08:48 PM
andyrad
Andy Radlgruber
None.
Fan Clutch Wrench
Does anyone in the Calgary area have a 1 1/4 inch fan clutch wrench I can borrow? A regular combination wrench does not fit in there.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old April 6th, 2011, 09:36 PM
You are probably better to ask on LRA forums or on the club mailing list as not many frequent here. Remember they are reverse thread. I've always found you can get in there somehow with a regular wrench.
Old April 6th, 2011, 09:54 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I heated and bent a regular open end wrench.
John Karlsson
Hope Valley, RI
Old April 7th, 2011, 09:34 AM
Naplm00
Matthew
yea a 1 1/4 craftsman wrench is only $20
Buy it, grind it, bend it
Old April 7th, 2011, 10:11 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Isn't the actual fan wrench only $17 ?
Old April 7th, 2011, 10:39 AM
Naplm00
Matthew
lol this I have no idea
Old April 7th, 2011, 11:33 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
It's actually a 36mm for the serp rovers and a 32mm for the non-serp Rovers. To get'em off...it's always towards the alternator. Rovers North has the double ended ones for cheap.
Old April 7th, 2011, 11:46 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I am in Calgary all next week. I have always gotten the off with a adj size wrench and a hammer. PM me if you are still stuck on Monday.
Old April 7th, 2011, 12:28 PM
andyrad
Andy Radlgruber
None.
I bought a combination wrench but it would not fit between the bolt heads for the pulley and the fan clutch. All I wanted to do was pull the fan, shroud, and radiator to make some engine work easier. I ended up saying screw it last night and just proceeded with the head removal for a gasket change and head inspection.
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
