Fan clutch removal - Defender Source
Old January 19th, 2009, 12:43 PM
flynn23
Scott Kozicki
97 NAS D90 SW
Fan clutch removal
Do I need to buy the special LR tools to remove this or will a crescent wrench of the right size (anyone know what it is? It's bigger than 32mm) do the job?
Old January 19th, 2009, 01:05 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
hammer and chisel, a couple of sharp taps.
3rd low and BOOT IT
Old January 19th, 2009, 01:06 PM
akfisher
robert hall
95 d-90sw
while the special tools may make it easier i took the advice i found here on one of the threads and used a crescent wrench as well. you can slide a wrench in there and then break the fan free with quick raps with a mallet. if you just turn the wrench as usual you will turn the whole assembly belts and all. also remember it is reverse threaded.
Old January 19th, 2009, 02:04 PM
btate
Bryan Tate
d90
97 isn't
Old January 19th, 2009, 04:07 PM
I put some rags in the fan belts and gave the wrench a whack with a hammer, came right off. Does anyone have any fan clutch reccomendations. I can not find an "HD" replacement. I know they are readily availible for the serpentine trucks, it is a GM part number if I recall. Ive got a replacement from autozone and they claim its the most heavy duty replacement they have, I can stop the fan by hand when my water temp gauge says 200 degrees, I dont like that worth shit.
Old January 19th, 2009, 05:30 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I bought the universal fan clutch and universal water pump wrenches from Atlantic British. It's the way to go. Makes it easy and doesn't damage anything.
Old January 19th, 2009, 10:34 PM
imola's Avatar
imola
borrow it from autozone...free of charge...
Old January 24th, 2009, 04:16 PM
flynn23
Scott Kozicki
97 NAS D90 SW
Same fit for the loaner from Autozone? Seems to be Ford oriented. Also, any recommendations on upgrades? The clutch assembly is awfully dirty from the outside and I bet the reason why it's seized. Worth rebuilding or replace it all together?
Old January 24th, 2009, 04:19 PM
You cant rebuild a fan clutch that I know of. Since youve got the 4.0 I think there is a "HD" Chevrolet application thats supposed to do pretty good. I dont know any part numbers, me thinks you could find one at the discoweb.
Old June 4th, 2009, 09:07 PM
TheBeast's Avatar
TheBeast
Dane Block
1994 D-90 #1440
Thumbs up Remove Fan Clutch
Originally Posted by rover4x4
I put some rags in the fan belts and gave the wrench a whack with a hammer, came right off. .
Thanks for the rag idea! I was having a hard time getting the fan clutch off. It took about 5 rags stuffed in the fan belts, a good wrench and a whack with the hammer. Off and fixed. Thanks!
Old June 4th, 2009, 09:20 PM
Wedge a screw driver in the bolts.
Old June 4th, 2009, 09:57 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Just wrap a rag around your hand (if your worried about cuts) hold the fan blade place the wrench then apply downwards in a quick like manner and voila you have a loose fan clutch
Old June 4th, 2009, 10:00 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
Atlantic British has the fan clutch wrench on sale right now for about $15. Also, the wrenches at Autozone will not fit- I tried them recently and every other place around that rents/loans them.
Cheers,
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old June 4th, 2009, 10:23 PM
Originally Posted by btate
97 isn't
Is this because of the serpentine belt setup? In other words, would a 3.9 from a 94 Discovery I with a serpentine belt also be normal thread (not reverse)?
Old June 5th, 2009, 10:25 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Since everyone has their own method, thought I would contribute mine. I use an adjustable wrench and channel locks. Close the channel locks all the way and bite onto the baside of the waterpump pulley. I clamp on to the rear lip of the pulley and the channel locks naturally brace agaist one of the waterpump bolts. Pull on the wrench and off it comes.
Old June 5th, 2009, 02:21 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
That would be correct. The water pump rotation is reversed from the v belt engines.
Old January 29th, 2010, 10:23 AM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
fan clutch
I am attempting to remove my fan and was curious if the fan is supposed to be able to spin in either direction? I can turn the fan by hand in either direction, I guess that is why some of the replies on this thread suggest wedging rags in the fan belts. Just looking for some confirmation so I know whether I should consider replacing the clutch while I have it apart. Thanks.
Old January 29th, 2010, 10:53 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The fan's viscous clutch will allow the blades to spin separate from the clutch in either direction, if that is what you are asking. Sometimes these are very hard to get off--I have a small map torch (propane will work too) that I used to recently heat up the not--it then came right off. I could not get it off otherwise and did not want to crack the nut which is what some people do on truly frozen situations.
Old February 3rd, 2010, 07:42 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone ever rebuild/change the fan clutch bearing on a Tdi ?
- Charles Eames
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
