Fan clutch question - Defender Source
Old March 17th, 2012, 10:21 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Fan clutch question
Question.
If the engine is hot and I turn off the engine, how tight or loose shou,d the fan be? I'm trying to figure out the fan clutch and I can't tell if it ends replacing.
Old March 17th, 2012, 11:11 AM
Naplm00
Matthew
Usually I would warm up the engine tooperatingtemp and then use a soft stick or something to tryand slow down the fan with the engine running. If you can stop it the clutch is bad, because warmed up the fan should lockup and turn at the pulley speed
Old March 17th, 2012, 09:33 PM
flananuts
Matthew
I'll try that. I did notice that the fan became more stiff as the engine cooled down vs warmed up.
Thx
Old March 17th, 2012, 10:48 PM
It needs to be a lot more than warmed up. The fan needs to get quite hot. It turns "On" and "Off". It is not progressive. You can hear it lock, if you listen closely.
Old March 18th, 2012, 06:23 PM
flananuts
Matthew
So if I'm idling in my driveway and the temp gauge is practically pegged, shouldnt the fan clutch be "locked" if I turn off tha truck and check immediately?
Old March 18th, 2012, 09:02 PM
Naplm00
Matthew
Yep must be hot at open temp
Old March 22nd, 2012, 05:52 AM
flananuts
Matthew
So the fan clutch is shot and I think it's the original on the truck. I will be replacing this weekend before the real heat arrives.
Old March 22nd, 2012, 09:46 AM
consider converting to an RRC fan ...
Old March 23rd, 2012, 07:07 AM
flananuts
Matthew
I'm going with an Imperial Fan clutch that was 40 bucks at advance auto based on a discoweb post a few years back. I looked at possibly an electric as well. I must say that my truck does a pretty good job cooling but it will of course cool a lot better once than fan is in fact working as expected. I also am going to do a valve cover gasket job this weekend as I noticed a bit of oil smoke coming up through one of the cover bolts.
Old March 23rd, 2012, 10:16 AM
I'll warn you that I tried the imperial and it was too strong/load and never kicked off (and you have to enlarge the fan bolt holes to use it. Likewise on the loudness with the non-genuine (britpart?) ones. The only ones that don't drive me nuts, but still cool properly are the genuine ones - in two different trucks. YMMV
Originally Posted by pendy
I'm here for the D's
Old March 23rd, 2012, 10:28 AM
Naplm00
Matthew
I prefer electric. Cleans up the engine bay and is very efficient. If wired with a good controller can cost $$ but the flexibility is nice.
Im using a Zirgo 16in fan
http://www.summitracing.com/parts/HFM-ZFB16S/?rtype=10
Spal Controller
http://www.spalusa.com/store/Main.aspx?html=pwmv3
and the spal optional temp sensor and a ebay 32mm hose adapter for the temp sensor.
This setup is great, the Zirgo fan just perfectly sits against the rad surround, witgh some nylon style fan mounts (thru core) it was tight and immobile. The spal controller is water resistant and internally relayed. You can use it with AC and override on or off switches. Fully programmable for temp on/off or cycling.
Downsides are:
you need a heavy gauge fused circuit and it relies on electronics instead of mechanical action
Old March 23rd, 2012, 12:45 PM
I've done electric. In the end I consider it one more thing to fail, and if everything is working as it should, the stock setup should be sufficient.
Old March 24th, 2012, 11:39 AM
Grover's Avatar
Grover
Spal Controller
Downsides are:
Got pix of your setup?
Cheers...
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
