Fan clutch install? Need instructions - Defender Source
Old March 4th, 2005, 04:47 PM
MiniGuy
Andrew Mobley
I am moving and my service manual is deeply buried in some box.
Does anyone have instructions for the install of a new fan clutch? I pray that this will solve my overheating problem. . . it should since I only overheat at idle or very slow off road speeds.
Any help greatly appreciated!
Thanks!
Old March 4th, 2005, 05:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
32mm wrench, left-handed thread. Turn the big nut that holds the clutch to the nose of the water pump. Send me the old one, so I can try and cross-reference other possiblities for the future.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 5th, 2005, 11:05 AM
MiniGuy
Andrew Mobley
Thanks Hans. . .
I remember someone talking a long time ago about how difficult it is to remove it because one needs a very narrow wrence.
Am I correct that bicycle shops sell a 32mm hub wrench that will slip in there easily?
I'd be happy to send you my old one if you really want it. . ..
Old March 5th, 2005, 06:01 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i've always used a screwdriver and hammer
just give it a sharp tap anti- clockwise
Old March 5th, 2005, 10:09 PM
bjenk
Brian Jenkinson
1994 D90
I just took mine off two weeks ago. It was a pain in the butt. I actually use a large cresant wrench for the fan nut that was able to clear the pulley and fan shroud. I would recommend getting a heavy duty strap wrench (sears $20.00) remove the crank shaft belt and wrap the wrench where the belt goes. I also had to use two cheater bars to extend the handle. good luck
brian
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
