Fan clutch how-to - Defender Source
Old December 13th, 2017, 12:49 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Fan clutch how-to
Yes, I've searched and all I can find is how to determine good or not.
Is there a step-step-guide out there on how to replace the fan clutch? I've ordered a replacement clutch and the wrench from Zack but would like some guidance before I start into this. 95 NAS Wagon btw
Thanks Board!!
KCD
Attributed to Shayne...
Old December 13th, 2017, 01:02 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Crack the nut with the wrench and spin it off. Nut is reverse thread.
http://www.defendersource.com/forum/...val-40545.html
Old December 13th, 2017, 01:08 PM
Naplm00
Matthew
Get pulley holder if you don't have one or massive waterpump pliers.
Hold pulley and loosen nut with the wrench (may have to put wrench on and tap with a hammer to break static friction)
Remove top bolts/nuts of fan shroud if equipped
Slip fan assembly out if the front of the shroud between the rad r frame and shroud.
Remove and replaced the fan clutch via four bolts
Put some antiseize on the fan hub threads on end of waterpump
Slip fan assembly back In
Lay fan in bottom of shroud
Put shroud back into place
Reverse thread the fan assembly back into place
Hold pulley and tighten nut
Debate why you went through this annoying experience and didn't replace it with an electric fan.
Tldr is a bitch to start the nut moving to remove and replace it. Have fun
Edit: Adam beat me to it
Old December 13th, 2017, 02:58 PM
DiscoDavis
C Davis
1990 110, 1995 Disco
Channel lock or plumbers pliers that are big enough to grip the whole pulley if your fan nut is stuck on like mine was. Copper grease the threads every once in a while to avoid it.
that nut is the worst part.
Old December 14th, 2017, 11:01 AM
kevincdoyle
Kevin C. Doyle
You guys..
are awesome...
Thanks much..
Will send photos as I attempt this..
KCD
Old December 16th, 2017, 01:15 AM
Fan clutch how-to
Sometimes the best thing to do is buy the friggin tool. Itís dirt cheap from RN. http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
They donít tell you this, but you become instant best friends with so many people once you have one.
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
