Fan clutch alternative part #? - Defender Source
Old October 17th, 2014, 11:56 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I must not be using the right keywords for the search, so I can't find a proper answer to this question! Hopefully, you will know what to look for and provide either proper keywords, direct links or first hand knowledge!
What part # can be used for a '95 V8 (v-belts) D90 fan clutch? I am looking for "OE"-type clutch (i.e. normal duty, not heavy duty) and hopefully, not have to (re)drill any bolt holes on the fan. I also would like to keep the fan shroud.
Evidently, I am looking for alternative part number I can get locally (i.e. not the OEM ERC5708 part which seems to retail in the $120 +shipping range).
And of course, now that I wrote this, I found this guy on rock auto.....
http://www.rockauto.com/catalog/more...211&cc=1187074
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 17th, 2014, 12:13 PM
Uro the cheapest out there and for that reason alone worth avoiding.
Old October 17th, 2014, 12:17 PM
Get a standard RRC fan clutch and the 11 blade RRC fan it's a great upgrade and fits with very minor adjustment of the shroud ... in my case it didn't need any modification at all.
don't whatever you do buy anything rated as heavy duty ... the will just run the fan more of the time, create noise and increase your fuel consumption for no benefit!
Old October 17th, 2014, 01:45 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Interesting line of reasoning for "heavy duty" clutches.
Had never considered that they actually LOWER mileage because they engage at a lower temperature.
Wonder how many diesel/ Tdi owners have considered this as a reason their engines run cold. ?
Old October 17th, 2014, 02:10 PM
ezzzzzzz
Mark Garrenton
I ran a GM 4.3 V6 fan clutch on my '96 Disco. I made a small spacer to move the fan into the stock location within the shrould but could done without it.
Old October 17th, 2014, 02:25 PM
So the thermostat will control the temp of the engine ... it's job is to basically keep the engine warm .... when the thermostat opens the coolant is cooled by flowing at volume through the radiator .... when that is insufficient the fan kicks in and more cooling is provided.
If the fan is engaged before the thermostat opens it's just consuming horsepower for no benefit.
a HD fan clutch wouldn't cause an engine to run cold .. only the thermostat controls that.
Old October 17th, 2014, 02:31 PM
That GM unit V6 unit is the one to go for.
Available as regular and heavy duty, which I assume references vehicles equipped with towing from factory. Get the bolt kit as well and ease the holes in the fan to accommodate the different thread size
Old September 24th, 2016, 11:29 PM
MonLand
Loic Fabro
Do you happen to have a part number? I'm going to try to find one tomorrow and the part store clerks are typically not so good with their computers....
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 25th, 2016, 12:21 AM
Go to rockauto. Great way to track manufacturers PN down. Two versions normal and HD for towing
Old September 25th, 2016, 08:14 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Loic-
For a GEMS truck try the Hayden 2626 (https://www.amazon.com/dp/B000C3F31G...I2819KOLXSAVXF)
This is NOT the HD unit that is often swapped in, that sounds like a C-130. It is a 'standard duty' unit but in using my scangauge I noticed no difference in terms of keeping the engine cool. It is what has been in Coyote for years now.
r-
Ray
Old September 25th, 2016, 08:51 AM
1996 CHEVROLET BLAZER 4.3L V6 Radiator Fan Clutch | RockAuto
Old September 25th, 2016, 09:12 AM
RRC fan and clutch, chebby vc only for serpentine configurations not v-belt
Old September 25th, 2016, 09:25 AM
Hayden 2772 is what fits the pre gems/motronic trucks
Engine Cooling Fan Clutch Hayden 2772 fits 87-95 Land Rover Range Rover | eBay
Have had one on my classic for a couple years now
Old September 26th, 2016, 09:22 PM
MonLand
Loic Fabro
Thanks guys!
Doug, that one shows up as heavy duty. Do you know what truck it would fit (so I can not look for a normal duty)?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 26th, 2016, 09:31 PM
Thanks guys!
It fits range rovers up to 95. The one I have is no louder than the oem fan clutch
Whats wrong with heavy duty ?
Old September 26th, 2016, 09:41 PM
MonLand
Loic Fabro
I don't know? folks seem to talk about airplanes.... I want to make sure I don't take off!
MonLand
1995 D90 NAS
1996 Discovery NAS
clutch, fan, fan clutch, part
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Fan and fan clutch MUDSUX Defender Technical Discussions 0 April 1st, 2010 01:14 AM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 03:12 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
