Fan clutch - Defender Source
Old October 1st, 2016, 02:25 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Fan clutch
I've long been curious if my fan clutch is working properly. With fall approaching I have some downtime so here's what I've found. Stock 1995 NAS with 3.9 V8. Engine off the fan can be spun by hand but it stops immediately and has no momentum or free spin. Cold start the fan engages with the start of the engine. Rolled up newspaper applied to fan immediately after starting truck and I can shred the newspaper if I want to. That fan ain't stopping for nothin. Am I correct that this is not how it is supposed to function? Shouldn't I be able to stop the fan upon starting the truck with little to no resistance?
This is where I'm supposed to write something witty and funny; or something.
Old October 1st, 2016, 02:44 PM
Chris B
72 + D1 drivetrain =?
Sounds good. If truck is hot and you can stoop the fan with newspaper then it's time to replace.
Old October 2nd, 2016, 08:27 AM
JBOD77
Jonathan
So it should run from the time you start the vehicle?? I thought it functioned like a thermostat and engaged when the vehicle was hot and shut off when the vehicle was cool??
Old October 2nd, 2016, 09:14 AM
Chris B
It will always run briefly at start up, then as necessary
Old October 2nd, 2016, 09:16 AM
You should be able to stop it when it is not engaged. It needs to get quite hot to turn on and lock up.
Old October 2nd, 2016, 05:34 PM
JBOD77
Jonathan
So what I've described is how it is supposed to be? I'm not following
Old October 2nd, 2016, 05:51 PM
Chris B
Thats the way it is. If you want something different, rip out the fan clutch and install an electric unit.
Old October 2nd, 2016, 06:13 PM
No. you should be able to stop it when cold.
Old October 3rd, 2016, 08:20 AM
JBOD77
Jonathan
So, it sounds like I've got a little project ahead of me..... anyone familiar with a write up on how to do the fan clutch that might be helpful. I've tried searching but can seem to come up with anything....
Old October 3rd, 2016, 10:17 AM
There is nothing wrong with your fan clutch ... you just haven't tested it when it's supposed to be locked up.
When cold they tend to lock up for a bit ... you here this as more air whoosh from the engine bay.
As the vehicle warms up they unlock and you can stop it with rolled up news paper.
When the vehicle gets really hot they lockup .... this is when the temp gauge starts creeping up well past the middle. They are there to increase the cooling capacity when the engine is HOT
If your temp isn't creeping up it means you cooling system is working well.
Old May 2nd, 2017, 12:22 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
reviving an old thread...
I was wondering if the fan clutch gets less efficient as they reach end of life? Meaning... you may not be able to completely stop the fan when it's on, but fan is certainly not as much air as when it was fresh/new?
I ask bc I recently had pretty much all the cooling components replaced (coolant, water pump, t-stat, rodded radiator/flow tested). THe only things that weren't replaced were the hoses and fan clutch.
After driving on the highway at 70mph for about 40min, I hit some traffic at the off-ramp... I noticed the temp gauge started creeping up past the middle. I turned on heater at full and as the traffic inched along, the temp gauge stayed around 3/4 mark (1/4 way before hitting H/red). Once I was moving again, gauge went back to middle.
I had my shop check the fan and they said it's fine (though, I'm not sure how they tested it). When truck is off, there is some resistance if I spin the fan by hand. The fan clutch is likely original (20yo). Trying to figure out if my fan clutch is going and that's why it wasn't able to cool the radiator when I was in traffic?
Thanks!
Old May 2nd, 2017, 03:44 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Originally Posted by lithium1330 View Post
reviving an old thread... I was wondering if the fan clutch gets less efficient as they reach end of life? Meaning... you may not be able to completely stop the fan when it's on, but fan is certainly not as much air as when it was fresh/new? I ask bc I recently had pretty much all the cooling components replaced (coolant, water pump, t-stat, rodded radiator/flow tested). THe only things that weren't replaced were the hoses and fan clutch. After driving on the highway at 70mph for about 40min, I hit some traffic at the off-ramp... I noticed the temp gauge started creeping up past the middle. I turned on heater at full and as the traffic inched along, the temp gauge stayed around 3/4 mark (1/4 way before hitting H/red). Once I was moving again, gauge went back to middle. I had my shop check the fan and they said it's fine (though, I'm not sure how they tested it). When truck is off, there is some resistance if I spin the fan by hand. The fan clutch is likely original (20yo). Trying to figure out if my fan clutch is going and that's why it wasn't able to cool the radiator when I was in traffic? Thanks!
Yes these things are flaky. I'd swap out asap and check coolant levels to ensure no air was trapped in system after replaced parts. The fan should roar under warm circumstances. Were you running AC at time? Couldn't of been too hot of a day yet? Start with fan clutch.
1973 Series 3
1991 Range Rover Classic
1994 Defender 90
2006 LR3 SE
instagram.com/ridgerovers
Old May 2nd, 2017, 05:47 AM
Chris B
Mine is suspect enough for me to have ordered up another. I only put my current one in three or four years ago. The quality of these parts has crumbled in recent years.
Old May 2nd, 2017, 09:39 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Zack was able to get me a nicer quality aftermarket fan last year. Great price. I now need to swap my T-Stat back to genuine since I now run too cool.
It is also handy to have Lav at your disposal to remove a stubborn fan.
1995 Defender ST
2008 LR3 HSE - Family Truckster
Old May 2nd, 2017, 09:41 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Once you figure out how to remove fan, it's a easy swap. I keep an extra on hand expecting one to go out.
1973 Series 3
1994 Defender 90
2006 LR3 SE
Old June 4th, 2017, 06:53 PM
Chris B
You keep a spare fan or fan clutch handy?
Old June 4th, 2017, 07:43 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Yeah I have 3 Rovers that use the clutch, they don't last as long as they used to.
1973 Series 3
1994 Defender 90
2006 LR3 SE
Old June 4th, 2017, 08:01 PM
Chris B
Agree on that. Replaced mine today to see if it would improve things. But I think the systems inability to control temp at slow or no speeds might be due to the Water pump. Its getting noisy.
Might be time to ditch that as well.
Old June 4th, 2017, 08:49 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I never run a fan clutch.
Everything about them are a PITA.
An electric fan triggered by a thermo-switch is a much more reliable setup.
With AC you can wire the cooling puller and the AC pusher to both come on when the AC is running.
Likewise the thermo-switch can trigger both fans to cycle on for cooling.
RDavisinVA
Old June 5th, 2017, 06:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
You could also have air in your cooling system. You should also have that double checked. Everyone seems to have different experiences and opinions but over 20 years driving NAS90's as daily drivers I've had to replace one. I personally stay away from electronics on these trucks. They don't ground well IMO and that becomes a ghost chase, whereas a spare fan is easy to pack and trail fix.
clutch, fan, fan clutch
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 08:10 PM
Fan and fan clutch MUDSUX Defender Technical Discussions 0 April 1st, 2010 12:14 AM
Size of fan bolts on viscous fan clutch imeek Defender Technical Discussions 4 September 26th, 2009 02:12 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 05:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 12:00 PM
