Fan Belts Replacement - Defender Source
Old August 14th, 2005, 11:44 PM
kleedee
Rob
I have a 94 D90. The belts have been squealing and I noticed the AC and Power Steering Belts are both loose. In addition, they both look to be cracking and old.
1. Can I buy these belts at the local Kragen/Autozone?
2. How difficult is it to change all the belts (AC, Power Steering, Alternator, and Water Pump)?
3. What is a fair quote for a shop to do all the work for me?
4. Any other suggestions would be appreciated.
Thanks.
Old August 15th, 2005, 01:23 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I got a new set of belts at NAPA, they had them all in stock.
But the power steering belt on mine is a seriously major pain in the ass, I have to basically remove the power steering pump to get the belt off since it's a double pully setup.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 15th, 2005, 11:08 AM
kleedee
Rob
What do you think is a fair price to replace all four belts and labor?
Old August 15th, 2005, 12:45 PM
Maybe $50 for the belts and maybe an hours labor.
Old August 15th, 2005, 07:22 PM
jabber
m j
110
For me the biggest pain in the arse was finding out that my water pump was going!!
I got my belts from NAPA. They work fine.... But they ARE a different size than OEM! It's only slight and they will work.
I ended up taking the pulley off the PS pump to get the belt on.
Cheers,
jabber
Old August 15th, 2005, 08:10 PM
Hans's Avatar
Hans
Hans Haase
I never used the OEM belts at all, do they go on/come off without dismounting the pump?
-Hans
My oil line fix
Old August 15th, 2005, 09:15 PM
jabber
m j
110
-Hans
I believe so... I had already purchased the Napa set, so I just used 'em. A friend of mine, who's helped me out with a TON of issues on my D90 and has been working on LRs for I would say more than 40 years... The Napa belts are a bit more deep than the OEM (probably due to the "teeth"). All I know... It was a bitch trying to replace all my belts.
All in all, at least for me, I didn't want to spend a bajillion dollars on friggin belts. Napa's will work.
ac, fan
Imperial Fan Clutch replacement souza Defender Technical Discussions 11 August 19th, 2008 11:36 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Fan replacement davedeojay Defender Technical Discussions 10 March 23rd, 2005 02:00 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
