Fair amount of Oil in Intake system - Defender Source
Old March 24th, 2015, 06:14 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I redid some of the awful plumbing from the intercooler to the turbo and at the same time replaced the air filter...I noticed a nice coating of oil in all of the pipes and in the intake...I assume most is coming from the oil breather cap hose to the air filter housing...firstly what is the purpose of that hose from the breather to the air filter...is it just reduce any pressure? Can it be removed if I bypass the whole air filter assembly and just use a reusable air cone attached a short way from the turbo inlet?
Surprisingly once I redid some of the plumbing that had a hard right hand 90 in it just after the turbo and a squashed 90 into the intake...both now have a silicone soft 90 hose...I also ensured everything is nice and tight and new paper air filter (old dirty K&N prior which will be cleaned), I lost 2 psi of boost.....but the engine actually felt much more responsive...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 24th, 2015, 06:22 PM
That whole oil breather to the intake thing is to keep the oil off the ground. It's for the children, beagles and the bald eagles. If you hate children, beagles and bald eagles you could run a hose down towards the ground or you could install an oil catch if your zen will take a hit. Once you do that any air cleaner could be used.
Old March 24th, 2015, 06:40 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
While I don't hate beagles, I prefer my Springer Spaniels...kids, well I prefer my Springers...lol..What if I just plugged the hole from the oil fill cap?...what is the actual function...release top end pressure?
Old March 24th, 2015, 06:58 PM
You will pop the cap off and kill a child, beagle or eagle. It needs to vent somewhere. Run the hose to a catch can and empty it from time to time.
Old March 24th, 2015, 09:58 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Sounds like the way to go...thx
Old March 24th, 2015, 10:57 PM
Having to clean the oily residue off intakes isn't uncommon in VW tdi's. So just get in there and clean it up
Old March 25th, 2015, 12:02 PM
lightwriter's Avatar
lightwriter
Carlos Ascencio
'84 One Ten
Yep, been there. Oven cleaner, a wire bristle brush and some hot water. An afternoon of fun...
Old March 25th, 2015, 12:54 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
The rubber donut on top of the valve cover that the oil fill cap fits into is missing and oil is constantly dripping from there...once I get the donut then a good steam and green engine cleaning for everything...oil is everywhere...and can't tell if I have other leaks until thats done!
Old March 25th, 2015, 02:52 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
That was a hilarious exchange....
Email is
Same place, new dogs.
Old March 25th, 2015, 02:58 PM
Are you consuming a lot of oil? If not, then don't worry about it. Nothing wrong with oil in the intake. If you are, then add a PCV oil cyclone if you don't have a stock one.
mount
Land Rover Genuine HD Springs - Amount of lift? Ride Quality? KKilo23 Defender Technical Discussions 0 September 14th, 2013 05:11 PM
Serious amount of free time! Campbell Misc. Chit-Chat 1 March 4th, 2010 02:50 PM
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Amount of brake fluid required for renewal JFD Defender Technical Discussions 6 September 23rd, 2008 06:24 PM
Air intake System mdmccallum Defender Technical Discussions 16 January 23rd, 2006 12:41 PM
