Failed emissions - Defender Source
Old January 25th, 2016, 05:22 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
Failed emissions
My D110 just failed ct emissions, does someone have an idea where I should start with this issue. They gave no indication of the specifics except "it's your emissions".
Old January 25th, 2016, 05:25 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Not sure if they have the same deal in CT, but here in Pennsylvania I registered my D90 as a classic. Only pay once and its good forever, plus only need annual safety inspection, no smog! Otherwise find a sympathetic tester and see if he can help. Good luck.
Angus
NAS 110?
Did they give you a print out of the failure sheet?
Old January 25th, 2016, 05:27 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
V8????? NAS????? year???
Diesel???
if they put it on the sniffer then there should be a print out...
good luck with your search
Old January 25th, 2016, 05:31 PM
Request specifics
Old January 25th, 2016, 05:39 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Is the Check engine light on? Did you get the failed sheet? if not try another shop...
CT anything (passenger) older than 4 years and younger than 25 years needs an emissions test every 2 years, outside of those parameters there is no emissions testing.
Old January 25th, 2016, 05:41 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
Sorry, Too busy wiping tears from my eyes.
1993 nas 110 V8 Gas. All stock Motor
Old January 25th, 2016, 05:52 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
Works like a charm. Add to full tank. Drive until tank is empty. Go pass emissions - use it every year on my NAS D110 and always works.
Robot Check
'93 NAS D110 #437
Old January 25th, 2016, 05:57 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by Lesandjes View Post
Works like a charm. Add to full tank. Drive until tank is empty. Go pass emissions - use it every year on my NAS D110 and always works. Robot Check
and they say my VW is cheating
Old January 25th, 2016, 05:59 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
This is interesting and worth a try. Is it worth diagnosing the problem and solving it?
I know at 10 mpg this will never be a daily commuter.
Old January 25th, 2016, 06:04 PM
Do you have a check engine light? If not, I would just do an oil change and tune up if you are due and put that treatment in if you must and try again. Note, a lot of the time, taking the truck in when it is fully up to temperature will allow it to pass easily.
PS I think it is funny when people driving such an expensive truck think 10mpg is an impediment to daily driver status when gas is $2 a gallon.
Old January 25th, 2016, 06:15 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
I have a VW TDi as well
I wouldn't even try to fix anything yet. Use the stuff and go pass emissions.
AndrewT
'93 NAS D110 #437
Old January 25th, 2016, 06:25 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
evilfij you are correct, and I usually don't dispense such hyperbole. Its more of an inconvenience but as inconveniences go this would be trivial.
I do have a check engine light, but who know if its work. The truck was meant to the a small project truck and was hoping to enjoy it a little before I started working on it.
Old January 25th, 2016, 06:28 PM
evilfij you are correct, and I usually don't dispense such hyperbole. Its more of an inconvenience but as inconveniences go this would be trivial. I do have a check engine light, but who know if its work. The truck was meant to the a small project truck and was hoping to enjoy it a little before I started working on it.
There is a little box under the passenger side dash. If you cycle the key you can read the codes. Then you can figure out what is wrong and fix it.
Old January 25th, 2016, 06:33 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
My NAS 90 didn't pass one cold December. My mechanic suggested driving it for a while on the hwy and taking it back all warmed up and it passed.
Old January 25th, 2016, 07:06 PM
Dollars to donuts you have an o2 sensor failed (code probably says 45..). If it's like mine your driveshaft has hit the passenger side o2 sensor and killed it. Evidence is denting of the o2 sensor body. Or it's something else since a code 45 covers about 85 different items. New cap, rotors and plugs usually help too.. I.e a tune up like Ron suggested. Good luck
Or it's loose, check with a 17mm wrench
95' D90 - daily driver..
Old January 25th, 2016, 07:11 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Same with Birdman. Here in Colorado the emissions testings facilities suggest bringing the vehicles in warm. Unless the printout is showing something is off, drive it like you stole it for at least 10 miles and try again.
Old January 25th, 2016, 08:16 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
Thanks for advice, I'm going to the mechanic tomorrow to check sensor, will add additive, go drag racing until gas tank is empty. Then go to a different shop.
Old January 25th, 2016, 08:36 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
In some states a check or service engine light illuminated is an automatic fail... I'd go back and ask for a printout detailing which section of the test it failed. It may have passed with flying colors except for the visual (check/service engine light).
Good luck.
Jay
Old January 25th, 2016, 08:55 PM
You don't need to go to a mechanic. The box is right there and will display codes as you cycle the key.
If it comes on when you first turn the key and then goes out, it works.
FAILED Maryland Emissions test Flagg Defender Technical Discussions 47 April 22nd, 2015 03:27 PM
Just failed NJ emissions inspection ymc226 Misc. Chit-Chat 4 June 25th, 2014 03:27 PM
Failed Emissions! Defender_90 Defender Technical Discussions 16 May 2nd, 2012 03:32 AM
Emissions – failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
