Failed emissions - Page 2 - Defender Source
Old January 25th, 2016, 09:53 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
The light does not come on when I first start car. I will check the bulb in the morning.
Old January 25th, 2016, 09:57 PM
If it comes on after 10-15 minutes .. (I.e. Heated up) then Loose o2 sensor is possible.. That's when it switches from open to closed loop..
Pull the pass seat and check the code, 5 min max diagnosis
95' D90 - daily driver..
Old January 26th, 2016, 09:10 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
OK code 45, Every one was correct., but I noticed that the Electronic Fuel Injection Control is from a 95 Disco. could this be an issue, or are they all the same. Just a thought before I looking for the exact cause (hoping its an o2 sensor)
Old January 26th, 2016, 09:31 PM
87 D110 (Ruby)
Sometimes code 45 can mean many different things. Start with searching the faults and start replacing the cheaper things first.
95 Disco uses the same engine management ECU, so should not be the issue (both are 3.9 engines, distributors, etc.. same as the Range Rover for that year).
couple of things to check for a CEL 45.
1) Damage to the O2 sensor body - if it looks beat up replace it - your drive shaft has hit it.
2) loose O2 sensor in the pipe.. 17mm wrench and check for tightness
3) loose at the engine side Plug - make sure it clicks in there good - if you can easy pull it out without squeezing the side clips - make sure the plug is seated all the way and does not come out - mine did this today basically a worn plastic plug - you can zip tie it together.
4) then Replace the O2
Do you know how to reset the codes on it?
1) open the passenger side cubby
2) locate the serial plug (its white with 4 pins - and is 2 pieces connected together. - just kinda hanging out near the ECU.. see picture attached )
3) ignition on (do not start the truck)
4) disconnect plug - wait 5 - 10 seconds - then reconnect.
5) turn off ignition - wait for the computer relay to drop out - you will hear a "Click"
6) turn ignition on (not started again) and check for codes again.. if none are present - then your reset, if there is another one it will now appear - Always do this if you see a CEL 44 - b/c there is usually a CEL 45 right behind it.
Other things that i have found cause CEL 45's
1) Corroded spark plug lead on the distributor - pull them one at a time and check - if you find some replace leads and Distributor cap.
2) leaking main hose (the big one from the MAF to the intake on the top of the engine.
3) Ignition amplifier
4) Coil (usually manifests as CEL 44 and $% with poor running then total cut out)
5) worn plug wires arcing on one cylinder (Passenger side in the case of CEL 45) - dumps fuel into the exhaust and causes backfires
6) exhaust leak Before the O2 sensor - where the header joins the exhaust down pipe.
... some others but those are the main ones that are easy to fix.
Serial Plug picture
Old January 26th, 2016, 09:38 PM
Nos4ra2's Avatar
Nos4ra2
Nos4ra2
1995 NAS D90 #2489
I will start this week end. Please give me all your opinions. It suck having to deal with this but it is alway great to learn more about working a on defender.
FAILED Maryland Emissions test Flagg Defender Technical Discussions 47 April 22nd, 2015 03:27 PM
Just failed NJ emissions inspection ymc226 Misc. Chit-Chat 4 June 25th, 2014 03:27 PM
Failed Emissions! Defender_90 Defender Technical Discussions 16 May 2nd, 2012 03:32 AM
Emissions – failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
