Failed Emissions! - Defender Source
Old May 1st, 2012, 03:58 PM
Defender_90
Kevin Doonan
1999 RR HSE
Failed Emissions!
Hello all,
So my 94 Defender 90 just failed emissions. Totally sucks, but I have until June to figure it out.
I was wondering though if anyone has any suggestions from past experiences for what it could be?
In CT the limit is 220 hydro carbons while at cruising speed, roughly 2750 rpms. I am at 260....
The other issue that I have is that the dealer installed A/C is hiding the hook up for my mecahnic to do a diagnostic on the truck? Any advice? should i just take the A/C out?
Any help is help!
KD
Old May 1st, 2012, 04:16 PM
Don't take the AC out ... the diagnostic port is a white 5 way connector that has a plug in it to loop out electrical noise. I can't imagine that it's completely inaccesible ... he may need to remove a couple of covers.
Old May 1st, 2012, 04:17 PM
Your own mechanic failed you?! What is this truck you bought? Post up some details. If he's your mechanic you'd think he'd have given you an idea as to what might be causing the issue. Do not take your A/C out it should be somewhat accessible.
I would suggest searching something like "hydrocarbons" and you'll find useful info as recent as this:
http://www.defendersource.com/forum/...t=hydrocarbons
Check your injectors, etc. as hydrcarbons is a result of unburnt fuel. I think there is a diagram in the PDF I already sent you of the proper order for them to check.
2750 is high rpm for cruising ... i tend to be lower and slower ...
------ Follow up post added May 1st, 2012 04:21 PM ------
The diagnostics on a 94/95 are pretty limited ... hopefully your mechanic has plenty of experience on these trucks ...
Old May 1st, 2012, 04:22 PM
change oil, do tune up, test hot. It will pass.
Old May 1st, 2012, 04:23 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
If you have a IR temp gun (cheap, $25 or so), measure the inlet and exit temperatures of your CATs for symmetry. If off, one could be partially blocked.
Old May 1st, 2012, 04:24 PM
has it thrown any fault codes??
Old May 1st, 2012, 04:31 PM
Defender_90
Kevin Doonan
1999 RR HSE
Thanks everyone for the input. But I just had a tune-up, some tune up eh? and I had driven on the highway for 15 minutes to the DMV and than to the shop to get it checked....looks like its going to be going back to the mechanic for a check up.... its been a tough two weeks finacially with the truck haha
Old May 1st, 2012, 04:35 PM
what is this truck you bought?
Old May 1st, 2012, 04:47 PM
Defender_90
Kevin Doonan
1999 RR HSE
Bought the truck from down in Nashville, TN. Red 1995 with badge 1219.
I will post pics when I get come. Had another LR guy check it out before buying and he said it was a solid truck. Hit 100k miles and speedo went dead and tried the fix, but it didnt work that well for me.
Only thing i know is that its killing my bank account haha thus I want to figure stuff out myself now.
Old May 1st, 2012, 04:49 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Check the vacuum line to the pressure regulator- split, or off, will run the fuel pressure higher than normal contributing to more unburned fuel, in conjunction with a manifold vacuum leak, without codes or poor running. CU14x isn't the smartest engine management system. Compotent, just not real smart.
Email is
Same place, new dogs.
Old May 1st, 2012, 04:53 PM
1995? I thought you had said it was a 1994 with square rear lights?
Ah, OK this one.
ID:	50959   Click image for larger version
Old May 1st, 2012, 05:09 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
If your mechanic has an exhaust gas analyzer (I assume he does since he does inspections), I'd ask him to test your catalyst efficiency. This basically involves testing the exhaust before the cats, then after, on similar drive cycles. You don't seem to far off, there's a good chance your cats are just a little tired. Ever replaced them?
Old May 1st, 2012, 05:29 PM
Defender_90
Kevin Doonan
1999 RR HSE
Ah, OK this one.
Thats it.
Old May 1st, 2012, 11:54 PM
carlosz's Avatar
carlosz
Carlos
leaking fuel pressure regulator, leaking injector, timing, bad vacuum timing advance unit, vacuum leak, defctve 02 sensors, defective coolant temp sensor, wide open or no thermostat thus not reaching proper operation temp, dirty intake filter and or defective cats, are some of the issues which would cause high hydrocarbon output.
as someone said before hydrocarbon is unburnt fuel...
you dont mention your engine running rough so im not going into the mechanical issues whch would make it run rich thus spew high hc's.
not putting down your mechanic, but he should have and idea as to what goes into the engine and what comes out as well as the reason for that mix.
with numbers so close, I would dare say timing is off by a few degrees, more than likely it is set at 10 btdc when it should be 6 btdc.
good luck.
Old May 2nd, 2012, 12:06 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Who's your mechanic?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 2nd, 2012, 03:32 AM
Suspect you bought a bit of an unmaintained dog which needs proper sorting before you'll make the emissions test.
Emissions failed Hydrocarbons PPM down_shift Defender Technical Discussions 5 October 20th, 2011 11:00 AM
Northern VA emissions question Arjun Defender Technical Discussions 17 May 26th, 2010 11:36 PM
Emissions question Rod Hayward Defender Technical Discussions 5 March 2nd, 2005 03:44 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Just failed an emissions test, suggestions? Hans Defender Technical Discussions 6 October 11th, 2004 12:12 AM
