Failed Electrics - Horn, Passing Lights, Clock, etc. - Defender Source
Old August 6th, 2015, 06:47 PM
justme
Justme
1997 D90 NAS CA Soft Top
Exclamation Failed Electrics - Horn, Passing Lights, Clock, etc.
G'Day All,
I'm facing Failed Electrics - Horn, Passing Lights, Clock, etc.
No blown fuses located.
However, when 12 VDC is jumpered from another source on the Rover to the clock everything works again.
Wierd?
Thank you in advance for your assistance!
D90 NAS CA '97 (Soft-Top of Course)
Old August 6th, 2015, 08:11 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Does the truck have an alarm?
Old August 6th, 2015, 08:31 PM
justme
Justme
No alarm aside from the anti-theft feature from factory.
Thanks.
Old August 6th, 2015, 10:49 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Those systems are all on different fuses and grounds, which makes me wonder if your fuse block has corroded out or something along those lines.
If I were home I would offer to help troubleshoot in person!
Old August 7th, 2015, 12:14 AM
87 D110 (Ruby)
Check your negative grounds mate
Old August 7th, 2015, 06:58 AM
Capt Milks's Avatar
Capt Milks
Exactly what stuff doesn't work? If it things that are on a switched power feed then it could be in the key switch also. The things you mentioned could be in an alarm circuit too. (Horn, lights etc) when you power the cigarette lighter you are back feeding the circuit. Be careful you do not fry the wiring harness.
Old August 7th, 2015, 07:29 AM
Could at least some of your problems be your turn signal stalk and/or a loose connection there at the steering wheel?
Old August 7th, 2015, 07:34 AM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
Good thought Josh - I recently lost turn signals, tails and break lights and gauges - Turned out to be a bad connection on the turn signal stock- Drove me crazy trying to understand this!!!!
Old August 7th, 2015, 08:32 AM
navydevildoc
Neill Thornton
Start with the basics. If you have a voltmeter, measure the voltage of your battery, then remove one of the fuses of something malfunctioning (like your cigarette lighter) and measure the voltage of the fuse terminal. They should be the same. That will at least show you have voltage available.
Then measure the voltage at the lighter itself. If you have ~12 volts, then you most likely have a dreaded ground issue. If you don't have at least 11 volts in all of those checks, then you need to figure out why power isn't getting to the devices to begin with.
Old August 7th, 2015, 06:34 PM
Defenderdude
Jason
1983 Defender 110
I have this exact problem it's been kicking my ass for awhile now, so you just checked were your turn signal switch connections?
Old August 7th, 2015, 07:22 PM
ATX_D110's Avatar
ATX_D110
Victor
Yes, pull the stalk and check all.
clock, horn, ht, lights
Passing of Bill Caloccia o2batsea Misc. Chit-Chat 8 October 11th, 2014 01:45 AM
Anyone passing through MD towards ME Rugbier Misc. Chit-Chat 8 October 6th, 2010 09:04 AM
Passing of the King o2batsea Misc. Chit-Chat 0 July 7th, 2010 09:28 AM
Tail lights Failed and I got arrested!! RickM Defender Technical Discussions 8 April 21st, 2008 06:02 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
