Factory Battery Cable Guage - Defender Source
Old January 27th, 2005, 04:10 PM
Anybody know what guage the factory battery cables are? Thanks.....
Anybody??????
Old January 27th, 2005, 04:11 PM
I would guess 8, maybe 6 or 4? If I was to replace them I would use 4 as it would be an upgrade.
Old January 27th, 2005, 06:06 PM
howellm70
Michael Howell
Actually I think its 2 gauge...I recently put in a 2nd battery and isolator and tried to match up with the stock stuff.
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old March 8th, 2005, 01:30 PM
jabber
m j
110
Rule of thumb
What's the rule of thumb for wire gauge and battery cable? I've been looking at replacing my battery cables, and I've found a source for 1/0 and 2/0 gauge cabling.
Old March 8th, 2005, 01:51 PM
The thicker the better with one caveat. The thicker the cable the stiffer it is. I used 1/0 for my winch and it was about like bending re-bar! I would say the 2 or 4 gauge would definitely get the job done. Warn Winches come with 2 gauge for their wiring kits.
Old March 8th, 2005, 02:00 PM
Mike J is right I looked at them last night and they are a little bigger then the 4 gauge wire I have so it must be 2. I would replace with the same or better.
Some info
at 15 feet long and 12 vdc
8 awg can handle 96 amps
6 awg can handle 155 amps
4 awg can handle 246 amps
2 awg can handle 403 amps
0 awg can handle 511 amps
00 awg can handle 645 amps
000 awg can handle 1039 amps
Wires longer handle less and shorter can handle more.
Old March 8th, 2005, 02:41 PM
If you get welding cable (instead of battery cable) it is much easier to bend and handle. Sizes are easily available up to 4/0.
This site has a decent and applicable chart for wire sizing in a vehicle.
Old March 8th, 2005, 04:20 PM
scoloco's Avatar
scoloco
'94 D90 ST
I got welding cable 1/0 guage when I hooked up my winch. No worries on routing it, it was more than flexible enough.
Old March 8th, 2005, 05:13 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
The stock stuff looks like 2.
One thing to keep in mind for winch wiring. The cable lengths will be a bit longer on a D90 than in other rigs, since the battery is mounter further away. Thus you want to use a larger guage than you use in other vehicles, all other things being equal. I used #1 in mine.
And don't forget that cut-off switch...
ac, battery, factory
Source for #2 Gauge Battery Cable Firemanshort Misc. Chit-Chat 7 July 27th, 2009 02:47 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
