Fabricators/ Machinist Question - Defender Source
Old March 5th, 2016, 05:14 PM
BlackField's Avatar
BlackField
Oscar
D110
I'm not a bad Googler but I'm not having any luck finding something like this in steel, I would need about 20 feet:
Old March 5th, 2016, 05:22 PM
Grover's Avatar
Grover
What's the application? Could you use angle iron and weld the middle 1/8" piece in place?
Old March 5th, 2016, 05:32 PM
BlackField's Avatar
BlackField
Oscar
D110
It has to support a piece of machined HDPE plastic sheet.
I'm sure someone could weld it up but I was hoping for something that would be off the shelf to keep cost down.
Old March 5th, 2016, 05:35 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
wgsonline: Satin Anodized Aluminum Mirror Corner Extrusion 47-7/8" Long
Or try bonnell.com
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 5th, 2016, 05:38 PM
Originally Posted by roverman2010 View Post
He wants steel.
I would seriously doubt you would find a complex section like that in steel. It required hot forming which is very complex and expensive. Aluminum, you should be able to find something close.
Old March 5th, 2016, 05:47 PM
roverman2010
1985 LR 90 200Tdi
There's no "F" in trying
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old March 5th, 2016, 09:24 PM
BlackField's Avatar
BlackField
Oscar
D110
Originally Posted by Red90 View Post
He wants steel.
F'n great.
Old March 5th, 2016, 09:30 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
A extrusion die is about 800 bucks plus running it
------ Follow up post added March 5th, 2016 09:30 PM ------
in aluminum
Old March 5th, 2016, 10:59 PM
Some things are working against you:
1. Strict dimensional requirements
2. Unusual shape
3. Very small quantity (a single stick of cold roll comes from mills in 24' lengths. You need 4' less than even a single mill stick.)
IMHO, unless you need the shape fully welded, having two angles welded together seems like the cheapest option.
For the cost of any custom fabrication option, it's actually cheaper for you to buy a nice welder and DIY.
Old March 5th, 2016, 11:03 PM
BlackField's Avatar
BlackField
Oscar
D110
I don't need it fully welded, just making sure I wasn't missing some special F shaped stock that was out there in some specialized field that I wasn't able to find on the net. Two pieces of angle spot welded every couple of inches will work.
ac
fabricators, which plasma cutter? rankar Misc. Chit-Chat 13 January 19th, 2016 03:24 PM
Roll cage fabricators in NY/NJ area? Naplm00 Defender Technical Discussions 27 January 26th, 2011 11:10 PM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
