fabrication advice - Defender Source
Old October 16th, 2006, 07:21 PM
94SW,4.6HSE,93LWB,83 110
fabrication advice
My 94 roll over truck's passenger rear inner fender well didn't straighten/flaten out to my satisfaction. I want to cut out the bent areas and rivet in new metal. I would prefer to find a trashed tub and cut the passenger rear out of it.
Otherwise my options are to search for someone with a large sheet metal brake and see what can be done.
Does anyone know of a damaged tub that may have the sacrificial inner wheel well or know of someone who can/would make me one ?
Old October 16th, 2006, 07:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Can you post pictures of what you need repaired. That would help us.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 16th, 2006, 07:39 PM
basically the entire "L" shaped wheel well from the front roll bar attachment point to the rear corner where the wires for the tailight come up through the gromet. My thought was to cut it off about 3/8 of an inch above the rear floor level. This part is spot welded to the exterior panels and for that reason a used panel may not be practical. Scorpion off road in the UK makes "bed liner panels" out of 5 bar that would be nice. John C tried to get them for me last month and no go.
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Vibration location! Advice please.. EdF Defender Technical Discussions 11 January 1st, 2006 05:29 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
auto transport advice mdmccallum Defender Technical Discussions 6 May 11th, 2004 05:58 PM
