Extremely Vague '83 110 Brake Question - Defender Source
Old June 23rd, 2010, 04:58 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
So I want/need to upgrade the front brakes on my '83 110. I believe the British redneck that built my truck installed RR axles, likely pre-92ish. The calipers are definetly single-piston, with the pads held in with springs and clips. The rotors are junk.
Anyhoo, I want to install dual piston calipers and vented rotors, any idea how to tell the year of my brake stuff? Looks like the newer brake stuff came at the 1986 year. I guess I am most concerned with whether the caliper bolt holes line up.
I know, very vague...
Update: so according to the RN website (http://www.roversnorth.com/store/c-156-front-axle.aspx) I have early D90 up to 1989 brake pads. So can I upgrade to larger calipers and vented rotors?
Semper Fi!
Old June 23rd, 2010, 05:21 PM
Pretty sure you can just fit D90 calipers and vented rotors as a bolt on. The only issue I know is some use metric bolts to hold on the caliper and some don't, but I don't think it is an issue.
Old June 23rd, 2010, 05:49 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
yes they bolt the same.
Old June 23rd, 2010, 09:54 PM
Yes I ran my D90 calipers on Janey for a spell, so I know they match.
Old June 23rd, 2010, 11:21 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Judging by the parts I have in my possession, you can also use the spacers/bolts from newer RRC calipers to convert your existing calipers to fit the vented disc. This is what I was going to do before I ended up with a D-90 axle.
Old June 24th, 2010, 09:23 AM
Can Discovery or Range Rover calipers fit?
Old June 24th, 2010, 10:54 AM
jetmech's Avatar
jetmech
Dave McHenry
Not the range rovers but for sure dico 1's will.
110, brake
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Advice on fitting a US-seven pin and electric brake controller onto a '83 110? turbodave Defender Technical Discussions 4 June 25th, 2009 02:48 PM
Brake Light Question waveridin1959 Defender Technical Discussions 6 May 4th, 2005 02:42 AM
