Extra hole in air intake? - Defender Source
Old September 14th, 2013, 02:44 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Hi. What's the large hole in the bottom of the air intake for? I have an '86 110 that was converted from 2.5td to 200tdi by a previous owner. Years ago, before I knew about the gaping hole in my air intake, I took the truck through a fairly shallow stream and ended up hydrolocking my engine. Since then, it's been covered with duct tape and plastic bags. While I have things apart though, I'd like to sort this out properly. I just have no idea what it's for, what to hook it up to, or what part I can buy to cap it off.
- Andrew.
1986 110 CSW 200tdi (
Old September 14th, 2013, 04:17 PM
- Andrew.
Once upon a time a hose came off that and went to the grate in the rear of the lf wing on 200 tdi's. Its where a snorkle hose would attach if you care to go that route. How does your engine get any air with that sealed off ?
Old September 14th, 2013, 05:12 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Wouldn't it suck through the bottom pipe pointing down?
On our conversions, we use an early 90s Chrysler 5th Ave air filter box. Tucks in nicely inside the wing and bolts to the galvanized splash guard completely out of the way.
RDavisinVA
Old September 14th, 2013, 05:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Pics? Would be interested in seeing how it looks and fits.
Old September 14th, 2013, 07:18 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I had the snorkel attached to the hole you can see on the top right, pointing up. Originally I didn't have a snorkel, but I didn't know there was a hole on the bottom, just waiting for water to splash up into it.
After "the incident", I installed a Safari Snorkel, as I said, onto the top hole. I sealed off the bottom hole with a plastic bag.
I still don't understand why the box would need two intakes. Was the other hole supposed to go somewhere, or what's the deal? I've looked at hardware stores for some sort of plumbing cap or something to go on there, but have never been able to find something the correct size.
Thanks again,
- Andrew.
Old September 14th, 2013, 07:31 PM
That diagonal hole is what is known as a SPOT. Stupid Previous Owner Trick. The one pointing down is the factory port and the diagonal one is some bodged up shite somebody welded on there. Best bet, cut it off and weld a plate over it.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 14th, 2013, 09:34 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I cannot conceive of a problem with the air box for which the solution would be to add a second intake. But OK, I guess it happened. It's off to the welder I go. Thanks!
Old September 14th, 2013, 10:01 PM
C391HAT's Avatar
C391HAT
Zach
86 110
I know what you mean. On mine a previous owner cut the port in half perpendicular to the box so it was c shaped. Maybe thought it would let more air in or something
Old September 15th, 2013, 08:29 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Chrysler/Fiat's new thing is to have dual air intakes called "Multiair". in the new Dodge Dart and Fiat 500. The previous owner was just ahead of the curve, LOL
Old September 15th, 2013, 01:23 PM
skrufy
Tim Timmins
1987/Defender 110
Air intake? Are you talking about the air filter housing? If so, the bottom hole is for a water drain, which should have a rubber drain cap on it with a slit type of opening- water can drain down, but no water gets in if going for a swim.......
Tim
Old September 15th, 2013, 03:22 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Tim
If you look at my photo, you'll see the small drain hole you're talking about, with the nipple on it. You'll also see two large intake holes. The second one of those is the one I'm talking about.
Old September 16th, 2013, 12:16 AM
skrufy
Tim Timmins
1987/Defender 110
Andrew-
Sorry, my mistake. The thumbnail pix of the extra huge and continuous Titanic sized intake hole didn't open up for me for some unknown reason.... When I asked the question, everybody else knew what you were talking about, but not me..... oh well. The drain hole with it rubber drain cap is easily seen as well..... As far as getting it welded up, I assume your welding guy will TIG-it, that metal is pretty thin for a MIG welder unless you run some real thin wire, and know what you are doing. For small stuff like that, the TIG weld will look better anyway.... Please post some "after" pix.....
Tim
Old September 16th, 2013, 08:16 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Andrew-
Tim
Haha no problem. There's a fabricator nearby I used for another small job, so I'll see if they're willing to do this, and fab up some brackets for my raised air intake. I'm going to keep the side intake and blank off the bottom one, as it makes fitting the intake hose easier.
Old September 16th, 2013, 10:00 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Fyi
FYI, the bottom hole is factory
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 16th, 2013, 10:05 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Yeah, but the side hole looks like it's going to fit more easily with my Mantec kit raised air intake kit.
Old September 16th, 2013, 10:46 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
twin snorkels/intakes?
when I had my last 90, i had the boost cranked up HIGH (24/28 psi IIRC) and needed two intakes to let it breathe better.
Old September 16th, 2013, 11:01 AM
GYM's Avatar
GYM
Gary
97 SW
New thing?
Take a look at any 1970 Hi Performance "Chrysler/Fiat" (Plymouth/Dodge). Single four barrel 383 and 440 engines had dual air intakes. Multi-carbed engines and single 4 barrel cars with hood mounted fresh air induction systems from that era had open air cleaner elements. (Chev and Ford had similar offerings.)
Everything old becomes new again.
Old September 16th, 2013, 11:02 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Maybe, but there's no evidence of the truck ever having a snorkel before I added one. I have a full-length Allisport intercooler, a slightly reworked turbo and tweaked fuel/air, and I've never gotten the impression that my vehicle was starved for air through a single Safari Snorkel.
air intake
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Air intake System mdmccallum Defender Technical Discussions 16 January 23rd, 2006 12:41 PM
Air Intake Cover wardnb Wanted 1 August 5th, 2005 08:53 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
