external shock tower (w/o cutting arch) - Defender Source
Old July 1st, 2008, 05:11 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I was wondering if anyone could direct me to an external front shock mount that does not require cutting the wheel arch? From the searching I have done it seems that most fit them by cutting a hole. I would really prefer not to do that. I think AB has one but I have eyelet to eyelet shocks. THanks.
Old July 1st, 2008, 08:35 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
If your goal is to run a longer travel shock, you will need to cut otherwise you will be limited to a short travel shock. I "think" some early RRs ran external front shocks, you could run that type of setup or something out of the UK designed to run dual front shocks may work.
Old July 1st, 2008, 09:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
exactly.. if you don't want to trim the wells, just run a stock setup. External setups will give you more flex but you need to run the longer shock which will require you to do some cutting to fit the setup. I had to trim mine a little bit and it looks factory. I also am running 14" travel shocks and a 3-link...
Legend in My Own Mind.
Old July 2nd, 2008, 01:00 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Right now I have 12 inch Bilstiens in the front using the stock setup with DII towers. Everything fits in nicely, I just want to move that shock outside the spring. How much lower do you think the top mount would have to be to fit it without cutting?
Loop mount front shock tower? cellulararrest Defender Technical Discussions 19 March 17th, 2008 09:20 AM
External front shock mount ini88 Wanted 0 March 25th, 2007 11:12 PM
external shock mounts sflash868 Defender Technical Discussions 1 May 8th, 2005 11:20 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
Fitted Rubber Shock Tower Retainers wicks Misc. Chit-Chat 21 March 28th, 2004 10:51 AM
