external cage fuel can rack - Defender Source
Old August 25th, 2016, 10:04 PM
Can someone point me to the thread or pics of the forum member that had a fabricator make his NAS 110 a tripple can carrier on the right side of his cage in the rear window?
My search ninja skills have failed me
Mark Kellgren
KM4BOR
Old August 25th, 2016, 10:20 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Not sure if this helps but I just ran across this pic today on Instagram. No idea who it belongs to though.
Edit: ah, noticed you wanted the external cage mounting, sorry.
Old August 25th, 2016, 10:29 PM
Mark,
A few clamps from these guys and you could fab one up in a few hours.
The picture shows chrome but the come in black.
http://axiaalloys.com/image/cache/da...43-150x150.jpg
Old August 25th, 2016, 10:34 PM
There's also these.
Old August 25th, 2016, 11:34 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Put them on the drivers side, how do expect to verify lane clearance when passing?
Old August 26th, 2016, 12:27 AM
Bling spot on an M-1? I don't think they give a crap.
Old August 26th, 2016, 01:33 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The Beagler has spent a career looking through view ports of M1 Abrams. Your concept of a blind spot differs from his.
I don't think an M1 even considers crushing things in a lane change, if they ever change lanes at all.
M1 traffic on my local streets is very heavy
Old August 26th, 2016, 07:41 AM
How about getting the long ranger tank that fits between the fill and tank. Himalaya also makes oversized tanks
Old August 26th, 2016, 08:44 AM
Well, you have all been extremely helpful and for that, I award you all turnips fresh from the garden.
Here's the thread. it's a tripple can mount that leverages the cage and keeps the cans as low profile as possible regarding protruding from the cage. I'm going to get something like this fabed up.
couple points to address raised concerns. I never look out that window. I have awesome visibility as is with the right side mirror being concave. Also, the left window is a gull wing hatch. somehow, 110 vans don't seem to crash anywhere in the world, so I think I'll be fine.
Also, I don't intend to run around with empty cans every day. that's camping kit that stays in the garage until needed. and this isn't a range problem. I have a water tank in my rear arch, but you always need at least one fuel and water can in my opinion, as you don't always have the ability to move the vehicle to the fuel or water supply. sometimes you need a medium to transport it.
http://www.defendersource.com/forum/...tml#post184383
Mark Kellgren
KM4BOR
Old August 26th, 2016, 10:18 AM
I think you would be much better off mounting them on the back next to the spare tire or else mounting them on the roof. That seems like it would be one of the worst possible places to mount them.
Old August 26th, 2016, 10:24 AM
why do you say that? I say the higher they are mounted, the worse off I am.
Mark Kellgren
KM4BOR
Old August 26th, 2016, 10:27 AM
Originally Posted by Overlander View Post
why do you say that? I saythe higher they are mounted, the worse off I am.
I can appreciate the need to keep weight down, which is why I suggested mounting on the rear. I meant a tire carrier with a mount for two jerry cans, which seems to be what you are after. I think mounting on the side is a bad choice because it will get hung up on trees. You live on the east coast, so this is an unfortunately reality. If you lived out west I could see this being feasible option. I'd rather have two mounted high on my roof than hanging off the side.
Old August 26th, 2016, 10:33 AM
Both ways have risks. Mine will include protection on the front for exactly that, and this approach is pretty low profile when you see that the cans only project a few inches past the cage itself, vs some of the other side mounted option shown earlier in the thread.
for me, on the back is not an option.
Mark Kellgren
KM4BOR
Old August 26th, 2016, 10:46 AM
I've always wanted someone to make a basket that goes over the spare tire. The footprint of four jerry cans is similar to that of a Pelican 1650. Spare tire racks are common on Jeeps, I'm surprised no one makes one for Land Rovers.
Old August 26th, 2016, 01:43 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Here's a photo of mine. Pretty simple design. Two HD cage clamps, a section a plate steel I bent into a shallow C profile and with 3 Rotopax mounts.
I can hold 2x 2gal cans on each mount, so 12 gallons total. I designed it so that the lower cage bar also supports the cans.
I am also ditching this mount and moving the cans to the tire carrier so I can install gull wing windows.
I considered driver rear visibility and tree damage, hence the drivers side mounting. I don't think I'd wheel it fully loaded with 6 cans, I'd keep it shallow at 3 cans across.
Semper Fi!
Old August 26th, 2016, 01:56 PM
Now you got me thinking! I like the side Rotopax idea.
D-90 External Cage Bozman Defender Technical Discussions 0 May 18th, 2007 10:08 PM
Front External Roll Cage Wanted ecmgbob Wanted 4 April 27th, 2007 02:58 PM
Front external roll cage JFD Wanted 0 October 25th, 2006 09:29 PM
Front external roll cage (front hoop) JFD Wanted 9 July 25th, 2006 06:38 PM
External front cage JFD Wanted 5 February 20th, 2006 08:31 AM
