Extended Wheel Studs - Page 3 - Defender Source
Old September 1st, 2014, 10:48 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by phoenix37 View Post
reviving a very old thread. Anyone find a domestic source for longer studs that don't cost a fortune?
Nope. I ordered 10 from lrseries.com a year or so ago and it wasn't cheap. Wonder how much it would be to get a batch machined.
Old September 1st, 2014, 11:13 AM
The studs on spacers are often quite a bit longer than stock if that helps. I recall you looking for spacers.
Old September 1st, 2014, 11:14 AM
phoenix37's Avatar
phoenix37
john
That part i know… I bought a new set of spacers but the studs on the hub are not long enough to mount them.
Old September 9th, 2014, 10:03 AM
phoenix37's Avatar
phoenix37
john
does anyone know the stock length of the early defender studs?. Came across three stud lengths 40mm 46mm and 60mm.
Old September 9th, 2014, 12:16 PM
I can check to see if we have any of the old ones we pulled off if Kent's truck tomorrow but suspect they hit the trash pickup already. It's likely the lowest number you quoted.
Btw, check with justin at lucky eight for the longer ones - he provided a couple for Kent's truck after I damaged them.
Originally Posted by pendy
I'm here for the D's
Old September 9th, 2014, 01:08 PM
phoenix37's Avatar
phoenix37
john
thanks Charles. I just ordered a set of these. Ill report back if they work.
http://www.ezaccessory.com/Wheel_Ada...1_5_p/st25.htm
Old September 9th, 2014, 02:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
thanks Charles. I just ordered a set of these. Ill report back if they work. http://www.ezaccessory.com/Wheel_Ada...1_5_p/st25.htm
Not a bad price at all - wonder what the length is on them.
Old September 9th, 2014, 02:40 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
IDK the length but the studs on my EZaccessories spacers were pretty long. I actually had to trim each stud about 3/16 - 1/4" so get my RRC solid nuts to thread all the way down.
Old September 9th, 2014, 02:52 PM
phoenix37's Avatar
phoenix37
john
I'm sure they are too long.. Ive got a call in to get an exact length but id rather trim than spend 200 bucks on 20 bolts!
Old September 9th, 2014, 03:15 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Werd
Old September 9th, 2014, 05:24 PM
phoenix37's Avatar
phoenix37
john
Overall length is 56mm thread length 33mm he wasn't sure that the knurled end would work but when he found out what 60mm ones were selling for he said if these didnt work they would consider making some.
Old October 4th, 2014, 05:18 PM
phoenix37's Avatar
phoenix37
john
Ok I'm pleased to say the ezaccessories studs fit. Nice to have a domestic source without spending stupid money on a a set of bolts.
ID:	104141   Click image for larger version
Old October 4th, 2014, 06:41 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Sweet - good news indeed!
Now to see if we can source a thin plate spacer say 10-15mm range to work behind these.
Old October 5th, 2014, 03:59 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Doesn't the wheel centre need to sit on the hub centre?
I'd thought of fitting a spacer myself as I've got the long studs, it crossed my mind that the centre from an old drum brake might do the trick. probably cheaper tin the long run to get something machined up though.
Mike Hammond
Old October 5th, 2014, 08:18 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by mikeslandrover View Post
Doesn't the wheel centre need to sit on the hub centre? I'd thought of fitting a spacer myself as I've got the long studs, it crossed my mind that the centre from an old drum brake might do the trick. probably cheaper tin the long run to get something machined up though.
I believe LR wheels are lug centric. I have heard of using old drum brakes for spacers. I might ask my welder buddy if he can cut one for me.
Old October 5th, 2014, 03:48 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Cool! Believe it or not, I still need to do this. In the meantime, I've probably put about 50K miles on the truck without a problem. But still just doesn't look right the way it is.
Old October 9th, 2014, 12:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I know that hub!
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 21st, 2015, 05:43 AM
Bear83
DUMAS Serge
1987
Are you satisfied (or not ?) by these studs ?
Thanks before ordering . . . (from France)
https://www.facebook.com/groups/1509324939313675/
wheel
LR3 bolt pattern and wheel studs trailerman Defender Technical Discussions 0 May 27th, 2006 10:32 AM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Extended wheel arch flares? THP90 Defender Technical Discussions 1 August 31st, 2005 02:26 PM
