Extended trip spares/kits - Defender Source
Old October 8th, 2009, 08:59 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Hi - I'm considering an extended trip (4-6 weeks) in the rig for next summer. Probably up north to Maine and then through much of Canada, down the west coast and ending up at my brother's house in L.A. Unsure how I'd get the truck back. Don't really want to think about that yet, but I am mulling over what parts to stuff in a pelican case for the trip. What is really necessary? My 90 is in pretty good shape, 125k miles with new exhaust, belts/hoses/plugs/wires, tie rod ends, springs/shocks, steering damper, etc. Drag link/track rod/panhard bar to and new water pump going in within the next month. And I don't expect to do massive wheeling, just hoping for lots of offroad driving. I'm thinking at least:
- Tire repair kit
- Tie rod ends (pair)
- Starter
- Fuel pump kit
- Brake switch
- Assorted belts/hoses (?)
- Fuses/relays
- Oil/fluids
Any ideas? What am I missing here? What should I replace beforehand (assume that very little has been replaced beyond what I mentioned above)?
Thanks. -Steve
-Ren Ching
Old October 8th, 2009, 09:16 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
wheel bearings, u joints half shafts if you have them.
hoses, hose clamps
Old October 8th, 2009, 09:37 AM
A powertank, impact wrench and a set of tools.
Old October 8th, 2009, 09:39 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
AAA card and phone numbers of all rover owners/shops along the way.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 8th, 2009, 09:48 AM
smob's Avatar
smob
Steve
That's a given.
-Ren Ching
Old October 8th, 2009, 02:09 PM
I'm following this with interest ... I'm thinking about a road trip but am a bit nervous of ending up in some backwater without spares ...
Old October 8th, 2009, 02:35 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Take a spare tie rod too, they're a so 'n' so to straighten if they get bent on the trail.
You're spares list more or less equates to what I took to drive across Europe for a 16 day trip around Morocco.
All the spares stayed mostly in the box, the tools got a bit of use though when the transfer box expired and I hadn't packed one of those!
But a spare was found and fitted in 5 hours in southern Spain - thanks to Trailmasters.
Mike Hammond
Old October 8th, 2009, 02:47 PM
Alternator, waterpump, since you have GEMS a lot of the ignition stuff is not applicable but I would probably take a crank sensor, water and duct tape will fix most hoses (unscrew the cap so it does not presurize and blow the fix if you do duct tape a hose). Two wheel bearings (I take a whole hub as it is easier).
I go with the minimum necessary to keep me moving so I don't carry axles, cvs, diffs, prop shafts etc, because I can continue if one fails. I do keep a water pump, alternator, serp belt, etc. because if they fail I am dead in the water. Basically make a list of the dozen or so most common things that prevent forward motion and use that as a guide to what to carry.
Old October 8th, 2009, 03:28 PM
smob's Avatar
smob
Steve
Thanks, you and Scott reminded me to get a better all-encompassing toolset. I'll also keep my old drag link and rod. And Ron reminded me that I need a backup alternator.
Anything from the electrical category? What about power steering or brakes?
-Ren Ching
Old October 8th, 2009, 03:40 PM
I usually keep a spare rubber flex line in my kit and brake pads, but I don't think that is necessay unless you are low on your pads to begin with. I keep a thing of fluid in the truck too. All I would keep for power steering is extra ATF.
Ron
Old October 8th, 2009, 05:05 PM
I don't think you need a comprehensive tool kit per se - most bolts are either 10, 13, 15, or 17mm with the odd 14mm in there (like on the driveshafts). If you have some combination wrenches, regular and deep sockets, ratchets, and ratcheting wrenches in those sizes you have most of what you need. Add in a torx 55 for the trans fill plug, a 1/2" drive extension for the t-case fill, and some screwdrivers, pliers etc and you'll be 90% of the way there. I'm sure there's more, but that's just off the top of my head. If you carry around a GMTK you're just wasting space and weight.
Old October 8th, 2009, 05:09 PM
mattarm's Avatar
mattarm
Matt
1993 D110
fuel filter
Old October 8th, 2009, 05:19 PM
Originally Posted by mattarm
fuel filter
Fuel fliter replacement kit with the rubber hose ends is better.
Old October 8th, 2009, 05:55 PM
GYM's Avatar
GYM
Gary
97 SW
You mentioned spare relays in your first post, just make sure to include a 1997 specific Multifunction Fuel Pump relay # YWB100820LG.
Old October 8th, 2009, 06:48 PM
If you can't get the fittings off the filter, you're probably just better cutting the hoses and putting in a BMW fuel filter that has two hose fittings - its a lot easier than cutting the hardlines and you'll never have to play with the threaded fittings again.
kit, spare, trip
Road Trip Report, Defender Sightings chris snell Misc. Chit-Chat 5 December 28th, 2005 03:03 PM
Yet one more Pa trip flippedrover Trips, Trails and Events 2 June 18th, 2005 09:35 AM
Hole in the Rock Trip with Bill Burke Maine 110 The Vendors Loft 0 March 2nd, 2005 04:13 PM
Grand Canyon - 4x4 + hiking. Planning info for a trip paulb Misc. Chit-Chat 7 January 20th, 2005 02:10 PM
