extended bump stops or spacers? - Defender Source
Old April 18th, 2014, 03:09 PM
jafir's Avatar
jafir
Jafir Elkurd
Seems like such a newb question.... but any opinions on what is better?
Old April 18th, 2014, 04:19 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
If your bump stops are good, try the red neck piece of 2x4 as a spacer
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 18th, 2014, 06:25 PM
jafir's Avatar
jafir
Jafir Elkurd
Good idea.
Old April 18th, 2014, 07:19 PM
robertf
Robert F
1995 Discovery
When you say spacers do you mean bump stop spacers or more spring spacer?
You've got to do bump stops. I skipped that part and had a spring spit out of my disco and trashed a tire as a result. Now I've got he floflex extended bumpstops AND the terra firma drop spacers to keep the 35"s out of the fenders. I can now pull the springs and ride on the bumps p38 style.
Old April 18th, 2014, 07:24 PM
jafir's Avatar
jafir
Jafir Elkurd
I was talking about spacers for the bump stops. I've got a set of +2 shocks, and when I had the rear springs out it seems like they'll just barely fit. I don't want to risk it, so I figure I should do something.
Old April 18th, 2014, 07:31 PM
robertf
Robert F
1995 Discovery
I'd throw those TF spacers on, they are cheap and easily removed if you want to restore it later. Maybe paint them black so they look less out of place on the truck. I wasn't too concerned about that on my disco
Old April 18th, 2014, 07:44 PM
jafir's Avatar
jafir
Jafir Elkurd
My 90 isn't really collectable. It's pretty beat up. Not much rust though. So I doubt I'd worry about restoring it back to stock.
Old April 20th, 2014, 01:53 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Another option is going with jounce bumpers... Or shock shaft bump stops in lay and terms ... Guys on pirate swear by them but you have to have your shocks tuned to your lift in order to have them replace your bumps... It's the way I'm going...
ac, top
RTE Shock Mounts, 8" Fox Shocks, Extended Bump Stops SMac Wanted 2 February 24th, 2013 07:39 PM
Terrafirma/Polybush Extended Bump Stops crown14 For Sale - Parts 2 December 17th, 2012 06:09 PM
Extended Rear Bump Stops CDeWan Wanted 3 October 11th, 2010 07:36 AM
Extended bump stops CDeWan Wanted 0 September 29th, 2010 01:13 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
