Experience fitting Disco auto trim in a 110? - Defender Source
Old March 9th, 2015, 11:30 AM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
My truck: 1988 110 SW with LHD 3.5 V8 with factory in dash AC.
Anyone out there have direct experience fitting a Disco II automatic transmission console and shifter trim parts into a 1988 110? I am looking into doing a swap from a 3.5V8 with Lt85 to a cammed and rebuilt 3.9V8 and ZF auto. I don't like the idea of spending $1K on the transmission trim parts from rovers north.
Also, any recs on Y-pipes with Cats that will fit? Do you know if the standard y-pipe for a classic will fit the imported 110 frame?
Any other things to watch out for when doing the conversion? I anticipate the following will have to be done:
1. engine and transmission swap including some frame adjustments and addition of wiring harness
2. new radiator with trans cooler (any idea if a classic radiator that has the internal trans cooler will fit in a 110?
3. Change out transfer case and shifter linkages (will be take from a classic or disco)
4. Update exhaust from manifold back including adding cats.
Thanks in advance!
110, disco
Rear 110 interior trim (aka boot trim) for sale ontheway For Sale - Parts 5 December 17th, 2014 11:07 PM
Springs and lift, bad disco experience... Broncoduecer Defender Technical Discussions 7 June 13th, 2011 10:27 AM
Early 110 split middle doors, any experience with them?? airbornrover Series Technical Discussions 6 May 13th, 2011 08:22 PM
Safety Devices Disco I and II rack fitting kits have arrived ECR The Vendors Loft 0 March 3rd, 2011 09:44 AM
anyone have experience in importing newer 110's for parts? NASD90 Defender Technical Discussions 0 January 19th, 2010 02:12 PM
