EXPANSION tank level - Defender Source
Old May 13th, 2014, 09:22 AM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
Guys,
Stupid question - and after all these years I should know it. Searched the forum and did not see it.
HOW MUCH FLUID should be in the expansion tank?
I can not see any fill line or anything when looking into that tank with a flashlight. Right now my fluid can be seen, and it probably 1/4" from the bottom - and you can see it move when you rock the truck.
I seem to remember that this was supposed to be a tank that was around half. Or was I supposed to just 'see' the fluid?
I need to dig into my manual when I get home from work.
FLAGG
Old May 13th, 2014, 10:36 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Half full is correct.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 13th, 2014, 11:51 AM
Flagg's Avatar
Flagg
Flagg
OK. Thanks.
Then I need to add some. Wonder if I can just pour some water in there. I should probably get to the store and buy the correct stuff
FLAGG
Old May 13th, 2014, 01:24 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
If you're going to put just water in it, at least make sure it's distilled water.
Ideally, mix the antifreeze of your choice with distilled water and then top off the tank.
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
I use Peak 50/50 premixed antifreeze. Whatever you choose, just make sure it's safe for aluminum.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old May 13th, 2014, 01:39 PM
Flagg's Avatar
Flagg
Flagg
OK - thanks for the very sound advice.
FLAGG
Expansion tank cap Mpigapicha Defender Technical Discussions 3 May 1st, 2012 08:26 PM
Expansion tank bleed hose trybul Defender Technical Discussions 0 December 5th, 2011 02:26 PM
Coolant expansion tank '01 disco genie90 Wanted 6 May 10th, 2011 05:44 PM
Coolant expansion tank '01 disco genie90 Wanted 0 May 10th, 2011 07:45 AM
Expansion tank leaking.. D90user Defender Technical Discussions 5 April 3rd, 2007 12:23 AM
