Expansion tank bleed hose - Defender Source
Old December 5th, 2011, 02:26 PM
trybul
Craig Hobbs
D90 83
Ok, so I have replace this hose with a new one, and it is leaking again...
I am wondering if the little "plastic" peice in the middle is important. Does it perform any other purpose other then be a joiner of the two feeds?
I have replaced it for now with brass fittings, and stopped the leak but if this peice is important then i should get another and replace my brass monstrosity
Below is a pic of the "plastic" peice in question
bleed
Coolant expansion tank '01 disco genie90 Wanted 6 May 10th, 2011 05:44 PM
hose from overflow tank to radiator defender1844 Smaller Projects 2 July 28th, 2008 11:08 PM
Expansion tank leaking.. D90user Defender Technical Discussions 5 April 3rd, 2007 12:23 AM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 04:05 AM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
