Exmoor Acoustic Mat Repair - Page 2 - Defender Source
Old September 8th, 2016, 09:29 AM
Originally Posted by Winston-Rover View Post
if you're not satisfied with the end result, you could hide the seam with a Mud UK Tunnel Tray:
MUD Defender Tunnel Tray - MUD Stuff - Products
Regardless of the result those trays rock. The thickness of the sound matting makes fitment a bit fiddly but the lt77 version screws in with the two top screws @ the rear of the tunnel nicely.
We have one in Trey's 4.2 auto 110 and even Trey the purist likes it.
Old September 8th, 2016, 09:12 PM
ghoregon
Greg H
1986 Defender 90 200tdi Ex-MoD
Originally Posted by speedpin View Post
What transmission do you have?
You will need to remove the hold down clasps for the under seat lids. You wont need them. Them weight of the mat hold the lids closed tight. you could keep them but would need to cut front edge of matting.
If you look at the bottom of the seat box matting then you can see an outline for the access lids, just cut out the front and sides, then you can flip the mat up to pull out lid. They lined up well on my ROW 110 but tight when sliding the lids out. Works fine for me.
I put bulkhead piece first (will bolt under fuse panel), floor matting, then I cut out e brake, and lids then laid the matting on the seat box. I then worked with a 3/8 drill bit and drilled holed over all the seat rail bolt holes. Don't drill the captive nuts under the matting if you have them. You will need M6x1 25 or 30 mm bolts (1/5 inch longer than stock screws) in length due to the added height of matting.
Seal up any holes in the floor and seatbox. last thing you want is preventable water intrusion points under the thick rubber matting.
Run any wires you think you would ever need to your console, you will not want to pull this stuff up anytime soon.
"three panels on top of the seat box"
If you don't have console and want the access to the center panel then cut away. I would not cut the center access panel in until you need access. Less cuts the better
Thanks a ton for the tips. I have an LT77 transmission, is your new rig an LT85? Your mats definitely look different, particularly the middle part of the seat box. Your front edge is molded into the mat whereas on mine, it looks like it needs to be cut out. Not sure why the difference in approach on that from Exmoor.
I will definitely get fresh paint down and my stainless kit from SDO installed before I put the mats in. Sounds like I won't want to be moving them once they are in the truck.
Old September 8th, 2016, 09:29 PM
ghoregon
Greg H
Yep, was thinking the same thing. Looks like Mud only has the R380 version for some reason. Lucky 8 still shows the LT77 RHD version I'd need for $85...hmm. Tell me does the spending on these trucks ever end?
------ Follow up post added September 8th, 2016 10:33 PM ------
Originally Posted by Rocky View Post
Greg on the backing selection, consider some black marine vinyl. Available at fabric stores.
For a test run, cut the vinyl to cover the transmission tunnel. Then add double sided tape or velcro to the exposed portion of the vinyl and put mat into position.
Marine vinyl, interesting option. I didn't know such a thing exists. Would this adhere better to the 3M 5200 than a rubber patch-like backing?
Sent from my SM-T520 using Tapatalk
Old September 10th, 2016, 06:37 PM
Ok, my matting showed up and required a few small repairs. Gorilla tape sticks to pretty much anything EXCEPT Exmoor acoustic matting. On to plan "B" whatever that is.
Old September 10th, 2016, 07:10 PM
ghoregon
Greg H
Good to know that isn't an option. I'm still leaning toward the 3M 5200, but curious to know if you find something that works well.
Sent from my SM-G920P using Tapatalk
Old September 10th, 2016, 07:23 PM
Options i'd do...
Uncle dougs suggestion
Gorilla tape
Or just deal with it (cut the tunnel part out in other words and throw some dyno mat stuff under the stock mat if you have one)
Edit, the mud uk tray fits like crap with the matting (I have one if you need it with 3 sockets)
95' D90 - Mostlydaily driver..
Old September 10th, 2016, 07:45 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I'd suggest not repairing with any glue type stuff until the mat is fitted in place.
It can take some....persuasion to get it in!
Rent my
Old September 10th, 2016, 07:53 PM
Chris B
72 + D1 drivetrain =?
I'm not convinced about this idea, but it's been bouncing around the old noggin since This thread started.
How about using a fiberglass repair kit?
Old September 10th, 2016, 08:01 PM
jafir's Avatar
jafir
Jafir Elkurd
Come on guys! Stitches. Girls like scars.
Old September 10th, 2016, 09:40 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Find yourself a person who does Plastic welding already
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 11th, 2016, 07:30 AM
4RF RDS
Kevin
2000 110 XS CSW
Automotive Goop. Ued that to glue a torn mud flap on a mates Defender and has worked for years now. Can't even tell where its torn. Get some between the tear and a blob on the back side.
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Old September 11th, 2016, 09:45 AM
Naplm00
M
I kinda wish mine was two pieces. It's bitch to get In/out for cleaning.
Anyway I vote for stitching, use plastic rexlace
https://www.google.com/search?q=blac...obile&ie=UTF-8
Old September 12th, 2016, 07:22 AM
I shot Drew Wright the manufacturer of these sound mats an email asking how he'd suggest
repairing the tears and got this response:
Hi Doug,
I’m sorry to tell you but they weren’t torn in shipment.
The sets are manufactured from a bad batch of material and will keep cracking.
They probably won’t stand up to the installation process.
Fit for land fill only.
This is our first quality problem in 15yrs and I’m very disappointed for customers that received them.
Needless to say we have fixed the problem.
Drew
Old September 12th, 2016, 07:31 AM
Naplm00
M
Wow what a bummer. Dosent look like these should have been sold
Old September 12th, 2016, 07:41 AM
speedpin's Avatar
speedpin
Looking ;)
RN sold these reduced at 110$ for a complete system. If they crack over the years so be it. I am sure they will last for a couple years. Should know if a few weeks/months if they will degrade quickly.
RN probably pursued replacements at no cost from vendor due to the defects.
~ Semper Fidelis ~
Old September 12th, 2016, 08:15 AM
ghoregon
Greg H
Dang, "fit for landfill purposes only". Yes, $110 is a steal for these assuming they hold up, but that statement from the manufacturer concerns me.
Old September 12th, 2016, 08:17 AM
jafir's Avatar
jafir
Jafir Elkurd
I wonder what the date range is of the defective ones. I've got a set sitting new in the box, but I've had it a couple of years I think.
Old September 12th, 2016, 08:23 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Hi Doug,
Iím sorry to tell you but they werenít torn in shipment.
They probably wonít stand up to the installation process.
This is our first quality problem in 15yrs and Iím very disappointed for customers that received them.
Drew
If they will keep cracking, maybe take this opportunity to back the complete pieces with some thin rubber. Vacuum bagging with a compatible adhesive perhaps? Just thinking out loud.
Old September 12th, 2016, 08:26 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Hi Doug,
Drew
The buyers knew what they were getting.
Damaged goods at a cheap price.
Thats about the price of some floor mats.
The installation process is brutal.
At least they'll sit in a truck as a test for a few years before the landfill....who knows?
Rent my
Old September 12th, 2016, 08:29 AM
Naplm00
M
Maybe glue the whole thing to black rubber pond liner?
ac, exmoor
Used 300tdi acoustic mat Broncoduecer For Sale - Parts 2 July 27th, 2016 02:19 PM
WTB - exmoor acoustic matting lt77 Hache Wanted 9 July 31st, 2015 05:08 AM
Exmoor Trim Acoustic Mat worth it? josh-man Defender Technical Discussions 40 March 20th, 2015 09:35 PM
Acoustic Molded Mat System R380 SafariHP Vendors 37 August 7th, 2009 12:21 AM
Anyone have experience with Wright Off-road - Acoustic Mat System themaxx Misc. Chit-Chat 9 January 19th, 2007 09:24 AM
