exmod lt77 and lt230 fluids - Defender Source
Old January 25th, 2016, 12:58 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
I've been searching but lots of conflicting info so I thought I'd ask here. I have a 1987 exmod 110 with the 2.5na and stock drivetrain. Looking for proper fluids for this combo, the big book says atf in the transmission and 90w in the TC. But some people calling for redline mtl, others saying use only synthetic atf in the lt77 as it has a weak impeller / pump.....
What works well and is relatively easy to find?
Old January 25th, 2016, 01:01 PM
Redline MTL in the gearbox.
Any 80W90 or 75W90 gear oil in the transfer case.
Old January 25th, 2016, 01:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
mtl made a huge difference when i got my first lt77 in a 1985 90
Old January 25th, 2016, 01:21 PM
DocB
David
1989 D110
I used Pennzoil Synthetic Syncromesh MTL for the transmission and I immediately noticed smoother shifts
Old January 25th, 2016, 01:36 PM
Honda MTF works great for me. Get it from NAPA for $6-7 a quart.
Old January 25th, 2016, 03:47 PM
boswalt's Avatar
boswalt
Brian Oswalt
1988 exmod 110
Sorry this ended up in series tech....fat fingers on a tiny phone.....
Found redline mtl at a specialty shop, $16 a quart.... must be magic.
Old January 25th, 2016, 04:09 PM
Really... Any 75W80 or 70W80 manual transmission fluid will work fine or really probably any 0W30 motor oil. Of things that are available in North America, the MTL has the best low temperature viscosity, which is helpful for extreme cold use.
lt230, mod
Whaer can i get fluids for a defender? (fluids, oils, etc.) Landyman1 Defender Technical Discussions 10 May 25th, 2013 12:08 PM
Fluids - Change diff and transfer case bossman429 Defender Technical Discussions 48 June 26th, 2012 12:27 AM
300tid/R380/LT230 Fluids trybul Defender Technical Discussions 13 July 26th, 2011 08:39 PM
R380 LT230 Fluids ronward Defender Technical Discussions 13 September 21st, 2006 11:28 PM
Changing fluids? Defender13 Defender Technical Discussions 1 July 24th, 2006 10:23 PM
