Exhaust system bolts - Defender Source
Old May 7th, 2004, 12:10 AM
just thought I would mention.. Other day my D-90 sounded like shit, like it was about to go, tickin and all when the motor was under load. problem was the bolts from the y-pipes to the manifold, I know this has been talked about in the past just thought I would mention it, it might be worth checking on yalls D-90's...... now it sounds like it should all is well for time being.
Old May 7th, 2004, 08:19 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I just had some cracks welded in my ex.system because mine had been loose and aparently the vibration caused it to crack at the flange.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old May 7th, 2004, 08:26 AM
When you first put on the exhaust the gasket between the 2 shrinks and allows the bolts to get loose, so after putting on an exhaust you have to retighten after a few days.
bolts, exhaust
New Defender 90 V8 (European) Exhaust System FS SafariHP For Sale - Parts 0 May 30th, 2006 10:26 AM
Anyone know where I can buy an OEM exhaust system for my 2.5 RHD NA Diesel in the USA solihul Defender Technical Discussions 5 October 7th, 2005 02:08 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Double "S" Stainless Steel Exhaust System edducati Defender Technical Discussions 11 July 23rd, 2004 10:43 AM
Building exhaust system kellymoe Defender Technical Discussions 4 February 23rd, 2004 05:04 PM
