Exhaust Routing- Stock or not? - Defender Source
Old March 13th, 2011, 07:54 PM
NoVaKevin
Kevin
sold#1469
My d90 has LR on the cats, so I believe the cats are original, or stock replacements at some point. I put the liquid steel on the exhaust to pass emissions, and it works great. The problem is that I missed a hole on top of one of the pipes on top going into the exhaust pipe, so I still get the exhaust smell. And, I want a permanent solution (new exhaust). I believe the current muffler is a Gibson, and has a sweet sound.
Is the muffler setup- 2 pipes (I believe each is 3.5inches around) into the muffler- stock? I want a magnaflow, but I think its one input and one output. What can be done to merge the 2 pipes from cats to muffler into 1 so I can get a magnaflow? FYI manifold gaskets are new, so I do not think there is any leaking there.
Name:	Exhaust Cats Back.jpg
ID:	36825   Click image for larger version
Name:	Exhaust Input.jpg
Name:	Exhaust Input 2.jpg
ID:	36827   Click image for larger version
Name:	Exhaust From Rear.jpg
Old March 13th, 2011, 08:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
Looking at your pics and I could be wrong but only one of your cats look stock to me. The other looks like it was cut out and replaced. Nothing wrong with that. As far as the two pipes that is not stock either. The stock design became one pipe before the end. Not that this is stock but it will give you an idea as the layout is the same as what came on your truck.
http://www.roversnorth.com/store/p-6...r-90-obd1.aspx
Old March 14th, 2011, 04:35 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Cats look factory to me. The original ones are different shapes like that.
I don't think Magnaflow has dual inlet mufflers, Flowmaster does http://www.summitracing.com/parts/FLO-8525554/
or you could just put a Y before the muffler.
Tony
1984 110 "Smokey" (sold)
exhaust
Stock exhaust fittings/couplings cgalpin Defender Technical Discussions 1 August 16th, 2010 12:20 PM
Exhaust - louder than stock, quieter than Borla? don Defender Technical Discussions 14 April 4th, 2008 01:36 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Stock 1997 NAS Exhaust ronward Defender Technical Discussions 2 October 5th, 2004 08:18 PM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
