Exhaust replacement - Defender Source
Old May 8th, 2012, 01:54 PM
StphNieuw's Avatar
StphNieuw
Stephan
Former owner of a 84 D90 RHD 2.5 NA
Exhaust replacement
Hi Guys,
The exhaust system on my 84 90 with a 2.5 NA Diesel engine is pretty much shot. I have reached out to RDS, DAP and i'm currently checking with RN. Up to now no one carries a down pipe, mid pipe and mid silencer.
Some thread searches showed folks going to a local muffler shop and getting custom work done. I have started to go down that route but was hoping folks knew part numbers for the mufflers that they had used. I have a good shop, with trustworthy mechanics and craftsman and they said they would have no problem creating it but asked me to check around if someone knew of any alternative parts that worked for them in terms of size fitment etc. No point in re-inventing the wheel I guess. Also what where some of the prices you guys had seen for this type of work. Some of the threads had seen about 150 but the two shops I went where quite a bit higher.
-Stephan
Old May 8th, 2012, 05:12 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
exhaust
I was about to list this, less than 500 miles been blown throu it.
Did you say nobody stocks these are out of stock?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 8th, 2012, 06:31 PM
StphNieuw's Avatar
StphNieuw
Stephan
So far two places don't have them. The guys at RN were putting a quote together for me. I assume most folks replace their with a off the shelf unit from somebody else. What type of LR did yours come off of?
------ Follow up post added May 8th, 2012 06:38 PM ------
I took a look at mine and it had the entry and exit on opposite sides of the silencer based on the picture it looks like both pipes are on the same side (looking at it via a iPhone so correct me if I'm wrong)
Old May 8th, 2012, 06:43 PM
bossman429's Avatar
bossman429
Adrian
1988 90
bring it to an exhaust shop and for $100 bucks they will probably make you a complete exhuast.
Typically i would drive to the most ghetto, most hispanic neighborhood you can find.
As for the muffler - whatever fits will work... nothing special about these things
ac, exhaust
Stainless exhaust replacement suggestions? stnmikita Defender Technical Discussions 10 December 23rd, 2011 02:30 PM
Complete Exhaust Replacement $$? dsh12 Defender Technical Discussions 12 April 18th, 2011 01:31 PM
Exhaust replacement kolvedic Defender Technical Discussions 1 March 29th, 2009 11:21 PM
Exhaust Replacement kleedee Defender Technical Discussions 34 January 10th, 2009 02:40 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
